Mobile power source for UP2 board and Intel® RealSense™ Robotic Development Kit
Piero78
New Member Posts: 3 ✭
in Peripherals
Hello, I've to make a mobile robot based on UP2 board and Intel® RealSense™ Robotic Development Kit.
My question is about the power source, I've to use a battery and I want to connect it to the GPIO pins (4 -> 5V and 6 -> ground).
I want to use this converter, can this solution power the board and the Intel® RealSense™ R200?
I will be interested to hear if they think this would work. I would think the 3amp output might be marginal for both the the UP2 plus the RealSense sensor.
I have not tried it yet on my UP, and don't have an UP2 yet, but in past on robot using boards like ODroid Xu4, I have used this BEC:
https://www.amazon.com/Castle-Creations-Bec-Switching-Regulator/dp/B000MXAR12/ref=sr_1_10
Right now I am playing around with my own RPI hat design to use with my Trossen Robotics PhantomX Hexapod
One board I am currently trying one of these from pololu: https://www.pololu.com/product/2851 connected to pins (2,4) for +5v and several of the GND pins
For some other boards, I have used: https://www.digikey.com/products/en?keywords=811-2179-ND
But again I have mainly tested on other boards as easier to replace RPI3 or Odroid than it is to replace the UP boards... But when I am satisfied with my soldering of current board will try on Up board.
Again I will be interested to see how well that BEC works for you. -
Wondering if you had a chance to try this converter with the UP board? We are also working on a mobile robot using the UP and RealSense. Was hoping I could get away with a USB powerbank, but not enough current.
Interested to hear your experiences. -
Have you tried any of there solutions with the UP board yet? Interested to hear how they went. Looking for a good mobile solution for a summer student project.
