New UP plastic chassis for HAT Expansion
Fabrizio
Fabrizio Guest Posts: 123 ✭
Hi all,
just to share with you the new plastic chassis with space for HAT expansions.
It will be available next June on UP Shop and via UP Resellers.
Cheers
  • Amit
    Amit New Member Posts: 4 ✭
    Looks good. I just bought the UPS HAT expansion board. Does this accommodate for heat-sink plate underneath the board?
    I have the current Up board that came with the heat-sink plate on the bottom and the finned heat sink on the top. I purchased the current enclosure and the board with the heat-sink cannot be placed inside the enclosure. As such my board is always "open".
    Also, if the new enclosure shown in your image does accommodate heat-sink then the enclosure needs to be able to "breathe" on the same side as the heat-sink is, else it will be heat-sink will be all enclosed inside.
    cheers!
