New UP plastic chassis for HAT Expansion
Fabrizio
Fabrizio Guest Posts: 123
Hi all,
just to share with you the new plastic chassis with space for HAT expansions.
It will be available next June on UP Shop and via UP Resellers.
Cheers
  • Amit
    Amit New Member Posts: 4
    Looks good. I just bought the UPS HAT expansion board. Does this accommodate for heat-sink plate underneath the board?
    I have the current Up board that came with the heat-sink plate on the bottom and the finned heat sink on the top. I purchased the current enclosure and the board with the heat-sink cannot be placed inside the enclosure. As such my board is always "open".
    Also, if the new enclosure shown in your image does accommodate heat-sink then the enclosure needs to be able to "breathe" on the same side as the heat-sink is, else it will be heat-sink will be all enclosed inside.
    cheers!
