active coolin
Mnietek
Mnietek New Member Posts: 4 ✭
I've just installed activ cooling but fan is not spinning. Why?
Maybe should I turn on fan in BIOS or somewhere?
  • Ken
    Ken New Member Posts: 48 ✭
    Check the instructions on where to plug the fan in, the place that looks obvious is the shrouded JST connector near the power switch, but that is actually for a reset switch. the fan gets plugged into the most inside pins of the tiny dual row header behind the outside doublestack USB connector.
  • Mnietek
    Thx - its working now....
