Up USB 3.0 OTG
Jimmy Mot
Jimmy Mot New Member Posts: 13
experimenting with UP 4/64
and windows 10x64
trying out usb 3.0 OTG with USB stick but not working
UP recognized it but if always fals away after a few seconds
what could be the problem
bad connection somewhere??
  • Dan O'Donovan
    We have seen some issues with the stability of the USB 3.0 connection with some cables and adapters, unfortunately. Trying a different cable or adapter may help.
  • Jimmy Mot
    found out
    was an USB hub on one of the USB 2.0 ports!!
    strange!!!
  • Matt
    Matt New Member Posts: 5
    FYI - I've seen instability with USB transfers. Resolved it by placing extra power between the USB device and the port. In effect, using a powered USB hub.
  • Jimmy Mot
    Indeed
    but here it was a bad USB 2.0 hub wich caused instability with the USB 3 OTG
