Up USB 3.0 OTG
Jimmy Mot
Posts: 13 ✭
in Peripherals
Hi
experimenting with UP 4/64
and windows 10x64
trying out usb 3.0 OTG with USB stick but not working
UP recognized it but if always fals away after a few seconds
what could be the problem
bad connection somewhere??
and windows 10x64
We have seen some issues with the stability of the USB 3.0 connection with some cables and adapters, unfortunately. Trying a different cable or adapter may help.
found out
was an USB hub on one of the USB 2.0 ports!!
strange!!! -
FYI - I've seen instability with USB transfers. Resolved it by placing extra power between the USB device and the port. In effect, using a powered USB hub.
Indeed
but here it was a bad USB 2.0 hub wich caused instability with the USB 3 OTG
