Ubuntu 16.04 Realsense problem
I 'm trying to install the r200 camera on my ubuntu 16.04 up-board.
I have the current custom kernel installed.
$ uname -r
4.4.0-2-upboard
I also had the problem with a faulty usb cable for the r200. however the new one i've bought works on my other ubuntu (14.04) pc
The otg adapter works when im plugging in other devices like usb-sticks or my smarthpone.
however $ lsusb doesnt give me any changes when i'm plugging the r200 in.
I dont know what else to check or to do.
Any help is really appreciated
(PS: I've also problems getting i2c to get data from my imu. and i'm totally unable to send anything over i2c. maybe these problems are somehow connected?)
EDIT: i've tested the exact cable combination (otg + usb to r200) on my smartphone and it recognized it.
So maybe there are no drivers in the current kernel?
$ uname -r
4.4.0-2-upboard
Would you mind posting the output of the following commands, and I'll see take a quick look to see if there are any clues in there?dmesg cat /sys/devices/virtual/dmi/id/board_version cat /sys/devices/virtual/dmi/id/bios_version lsmod cat /boot/config-`uname -r` uname -a
-Dan -
thank you for your quick reply!
so dmesg is on the following link
http://pastebin.com/EMCiLvHccat /sys/devices/virtual/dmi/id/board_version V0.4
cat /sys/devices/virtual/dmi/id/bios_version UPC1BM0S
lsmodModule Size Used by binfmt_misc 20480 1 nls_iso8859_1 16384 1 spidev 20480 0 intel_rapl 20480 0 intel_powerclamp 16384 0 coretemp 16384 0 kvm_intel 172032 0 kvm 552960 1 kvm_intel irqbypass 16384 1 kvm punit_atom_debug 16384 0 crct10dif_pclmul 16384 0 crc32_pclmul 16384 0 ghash_clmulni_intel 16384 0 aesni_intel 167936 0 aes_x86_64 20480 1 aesni_intel lrw 16384 1 aesni_intel gf128mul 16384 1 lrw glue_helper 16384 1 aesni_intel ablk_helper 16384 1 aesni_intel cryptd 20480 3 ghash_clmulni_intel,aesni_intel,ablk_helper joydev 20480 0 input_leds 16384 0 snd_intel_sst_acpi 16384 0 snd_intel_sst_core 73728 1 snd_intel_sst_acpi snd_soc_sst_mfld_platform 90112 1 snd_intel_sst_core snd_soc_core 225280 1 snd_soc_sst_mfld_platform mei_txe 20480 0 shpchp 36864 0 mei 98304 1 mei_txe snd_compress 20480 1 snd_soc_core lpc_ich 24576 0 ac97_bus 16384 1 snd_soc_core snd_pcm_dmaengine 16384 1 snd_soc_core snd_seq_midi 16384 0 snd_seq_midi_event 16384 1 snd_seq_midi snd_rawmidi 32768 1 snd_seq_midi hdmi_audio 45056 1 snd_pcm 106496 4 hdmi_audio,snd_soc_core,snd_soc_sst_mfld_platform,snd_pcm_dmaengine snd_seq 69632 2 snd_seq_midi_event,snd_seq_midi intel_hid 16384 0 snd_seq_device 16384 3 snd_seq,snd_rawmidi,snd_seq_midi snd_timer 32768 2 snd_pcm,snd_seq 8250_fintek 16384 0 sparse_keymap 16384 1 intel_hid ti_adc081c 16384 0 snd 81920 11 hdmi_audio,snd_soc_core,snd_timer,snd_pcm,snd_seq,snd_rawmidi,snd_soc_sst_mfld_platform,snd_seq_device,snd_compress industrialio 65536 1 ti_adc081c pwm_lpss_platform 16384 0 soundcore 16384 1 snd pwm_lpss 16384 1 pwm_lpss_platform tpm_crb 16384 0 spi_pxa2xx_platform 24576 0 8250_dw 16384 0 int3400_thermal 16384 0 acpi_thermal_rel 16384 1 int3400_thermal int3403_thermal 16384 0 int340x_thermal_zone 16384 1 int3403_thermal acpi_pad 20480 0 mac_hid 16384 0 parport_pc 32768 0 ppdev 20480 0 lp 20480 0 parport 49152 3 lp,ppdev,parport_pc autofs4 40960 2 hid_generic 16384 0 usbhid 53248 0 hid 122880 2 hid_generic,usbhid mmc_block 40960 4 i915 1241088 7 hdmi_audio i2c_algo_bit 16384 1 i915 drm_kms_helper 155648 1 i915 syscopyarea 16384 1 drm_kms_helper sysfillrect 16384 1 drm_kms_helper sysimgblt 16384 1 drm_kms_helper fb_sys_fops 16384 1 drm_kms_helper drm 368640 8 i915,drm_kms_helper r8169 81920 0 mii 16384 1 r8169 fjes 28672 0 video 40960 1 i915 sdhci_acpi 16384 0 sdhci 49152 1 sdhci_acpi
is attached as file, it was too big for pastebin
and finallyuname -a Linux Bot-Pc 4.4.0-2-upboard #12-Ubuntu SMP Thu Dec 1 15:01:52 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
Thanks for that. I can't see any obvious issues there, everything looks normal.
Focusing on the I2C issue for now, can you tell me more about the symptoms that you're seeing and how you are testing it?
