Problem with Ubilinux OS with the 10.1" LCD Panel and UP Board
Atul Vaze
Atul Vaze New Member Posts: 5 ✭
Recently I have purchased 10.1" LCD Touch Panel and UP Board with 2GB Memory /16GB eMMC storage.
Following the instructions from "KIT-101JDHX30BP1U1 Assembly Guide Rev01.pdf" I have assembled the LCD Touch Screen with UP Board.
I connected the HDMI monitor and after power on -> BIOS Settings->Chipset->North Bridge-> Panel ->Enabled.
Selected the resolution as 1280x800
Saved the settings and then LCD started working.
I have downloaded the Ubilinux ISO Image and tried to install on UP Board.
( I have downloaded the image for UP Board community-downloads "ubilinux-3.0.iso"
After the installation was complete and system was re-started it was booting and was stuck as shown in the images attached.
After this I disconnected the LCD Touch Panel from UP Board.
I connected the HDMI monitor.
Then I again entered the BIOS settings and disabled Panel mode.
The system was booted properly without any issue.
This shows there is a issue when Panel is enabled and LCD Touch Panel is connected
Can you help me to resolve this issue?
Do you need any other information?
Atul Vaze
Akshay Microprocessors Pvt Ltd
Pune,INDIA
  • Atul Vaze
    Hello UP support team,
    Please reply regarding the issue explained above.
  • Jaap Crezee
    Jaap Crezee New Member Posts: 19 ✭
    You might want to try flashing the bios: https://up-community.org/downloads/uefi-bios
  • Chris Botha
    Chris Botha New Member Posts: 48 ✭
    Same issue with the 7 inch.. believe it or not, its not actually supported in linux. So no hardware screen support in linux, only gpio on off support in windows.. rock and a hard place. My UP is a nice desktop paperweight anyhow.
    At the moment we are doing our best to enable support for as many peripherals and I/O as possible.
    The Linux 4.4 kernel does not handle MIPI 3.0 which is required by Cherry Trail SoC to drive MIPI Display and there are also some distribution specific software in the middle which are causing other issues.
    At the moment we are trying to provide a stable and reliable platform, running a 4.4 Linux Kernel with as many features as possible. We are working actively to improve the software to enable what is still not fully supported.
  • Atul Vaze
    Hello UP Board Support Team,
    Today I have got the solution for 10.1" LCD with UP Board problem.
    This I have done just by fluke, no technical explanation.
    I changed the BIOS settings as follows -
    Boot-> OS Image ID -> [Android]
    It worked!!
    Earlier it was Windows 8.1
    Now its working fine!!!
    Please check and if possible inform me the reason why it worked
    Atul Vaze
  • Pelle
    Pelle New Member Posts: 5 ✭
    And the O's that you use is still ubilinux and not android¿
  • Atul Vaze
    OS is Ubuntu 16.04
