Does HDMI audio work?
Erin Park
Erin Park New Member Posts: 3 ✭
Hi All,
I have the Upboard UPT-CHT01-A10-0464.
I made the build by myself using the instruction in the release.
https://github.com/emutex/meta-up-board (Yocto)
The HDMI video playback is working fine but the I do not hear any sound from the HDMI monitor.
Does UpBoard HDMI Audio really work?
B.Regards,
Erin
    Hi Erin,
    Could you please double check that the meta-layer is actually included properly in the build?
    For example you can try some of the I/O to make sure that the UP kernel changes have been included. If not, then the kernel resulted from your built does not include the UP patches in the meta layer.
    https://up-community.org/wiki/Pinout
