UP Boards power draw
Mikolaj
New Member Posts: 6 ✭
What's the power draw of the UP! board and predicted/tested for UP!^2 ?
What's the maximum voltage accepted by the board's power circuit ?
I've just made some test with my UP board.
The maximum current I've measured is 1.5 A @ 5 Vdc.
The maximum power supply voltage must be 5.2 Vdc (https://up-community.org/forum/public-upboardhw/335-voltage-supply-tolerance#1023) -
Thank you for your answer De Benedetti.
Have you tried it with Intel BurnTest / Prime95 to make sure that the system utilized the maximum CPU power during the measurement ? -
I've Ubuntu 16.04 LTS desktop installed.
I run a stress test with all the 4 cores at 100% using "stress-ng" package (sudo apt-get install stress-ng). -
OK, thank you very much.
must be LESS than 5.2V !!
what extras did you have drawing power from the source ? (like monitor, USB devices etc) - if so the board requirements are really low, nothing close to 4A
