FW Update: How creating UEFI bootable USB drive?
Nic
Nic New Member Posts: 8
edited October 2016 in UP Board Linux
I am not an Linux or Uefi expert, but i would like to upgrade the FW on my up-board because I covered lots of problems (USB-3 etc). For the moment I do not know how can I create an UEFI bootable USb drive as a starting point?
Thank y for any help,
Nic
  • Chris Botha
    Chris Botha New Member Posts: 48
    as no one else is interested in answering. Use Rufus. https://rufus.akeo.ie/
    set partition type to gpt and point it to your ISO. note that when you load the iso it will default back to MBR, be sure to set ti back to gpt.
  • Jaap Crezee
    Jaap Crezee New Member Posts: 19
    What works for me:
    Get grub compiled for x86_64-efi, create a first FAT32 partition on the disk:
    ./EFI
    ./EFI/BOOT
    ./EFI/BOOT/grub.cfg
    ./EFI/BOOT/BOOTX64.efi
    grub.cfg contains the normal grub config; BOOTX64.efi is the grub EFI binary (which includes required drivers/modules).
    This works on both the UP board as well als in QEMU & VirtualBox.
  • Nic
    Thanks, but what do y mean by "Get grub compiled for x86_64-efi", I am not an expert in Linux or UEFI stuff.
  • Jaap Crezee
    I got mine compiled using buildroot. I have attached the binary which you can use if you like.
    Hi Nic,
    You can simply format a USB drive as FAT32 and then you should extract the content of the new BIOS package from here (which includes the EFI shell and boot): https://up-community.org/downloads/uefi-bios/uefi-bios-upc1bm0x
    Follow the instructions on that page to update the BIOS.
