10-pin connector CN7 (UART0) - Which FTDI serial cable to use?
m
New Member Posts: 15 ✭
Hi!
I have a question regarding the "10-pin connector CN7 (UART0)" which I hope to get an answer to. I want to buy a FTDI serial cable to use together with the 10-pin connector CN7, but there exist FTDI cables with different currents (3.3V, 5V, etc.). Does anyone know which current is the right one?
Thank you very much!
3.3V is the right one to use.
More info on how to wire the cable can be found here: https://up-community.org/wiki/Serial_console -
Great! Thank you.
I was actually reading that page, but information about the voltage was missing. Maybe it is a good idea to add this information. -
Just added, thanks for reporting!
Thanks for adding!
