Win 10 drivers issue
Massimo
Massimo New Member Posts: 2 ✭
Just installed Win 10 PRO version 1511 Build 10586.164 (x64 version). When I try to install your drivers WIN10_64 - Step_1-Chipset_and_peripherals through it's Setup.exe file it reports a failure message: "The setup program ended prematurely because of the following error: [string ID not found]"
What do you suggest to do?
  • Jacky Kuo
    Jacky Kuo New Member Posts: 70 ✭
    edited July 2016
    Hi Maxmax,
    Are you login as administrator?
    You can try "Right click" on Setup.exe ->"Run as administrator" to run installation.
    Or "Right click" on Setup.exe -> "Properties" -> "Security" to give current login account "Full control" permission.
  • Nate
    Nate New Member Posts: 4 ✭
    Same issue here. Get String ID Not Found error. Running as admin and I also tried copying theWIN10_64 folder to the desktop as was mentioned in another thread. Please provide guidance on how to install drivers for Windows 10 64-bit ASAP.
  • Nate
    Here is my log file contents:
    12:24:01:577: >>> Log start
    12:24:01:587: Core version: 2.0.5
    12:24:01:597: Setup version: 2.0.0.11
    12:24:01:607: Command line: "C:\WIN10_64\Setup.exe"
    12:24:01:617: OS data: 6-2-1-0 64-bit
    12:24:01:627: System up time: 576 sec
    12:24:01:637: Current UI language: 0409
    12:24:01:647: Language folder: C:\Users\UP_LOC~1\AppData\Local\Temp\IIFCD99.tmp
    12:24:01:717: Found C:\Users\UP_LOC~1\AppData\Local\Temp\IIFCD99.tmp\en-US\IntelCommon.dll. Lang 0409. Rank 3
    12:24:01:767: Relaunching setup as elevated
    12:24:03:920: Dumping MSI properties (0 total)
    12:24:03:940: Exit code: 0
    12:24:03:950: >>> Log End
    12:24:03:990: >>> Log start
    12:24:04:000: Core version: 2.0.5
    12:24:04:020: Setup version: 2.0.0.11
    12:24:04:040: Command line: "C:\WIN10_64\Setup.exe"
    12:24:04:050: OS data: 6-2-1-0 64-bit
    12:24:04:070: System up time: 579 sec
    12:24:04:090: Current UI language: 0409
    12:24:04:100: Language folder: C:\Users\UP_LOC~1\AppData\Local\Temp\IIFD72F.tmp
    12:24:04:180: Found C:\Users\UP_LOC~1\AppData\Local\Temp\IIFD72F.tmp\en-US\IntelCommon.dll. Lang 0409. Rank 3
    12:24:04:230: Package version: 2.0.1.14
    12:24:04:250: Installed version: <Not installed>
    12:24:04:270: This is a clean install
    12:24:04:280: Setup mode: Installation
    12:24:04:300: Looking for OS: 6.0
    12:24:04:320: OS check passed
    12:24:04:340: .NET not required, skipping requirement check
    12:24:04:360: Driver source is C:\WIN10_64\Drivers
    12:24:04:380: Using folder 'C:\WIN10_64\Drivers' as the driver source
    12:24:04:400: Scanning all active devices
    12:24:04:460: E Win32 exception occurred!!
    12:24:04:480: Error code: 0xE0000100 (-536870656)
    12:24:04:500: Error text: ''
    12:24:04:520: Extended error text: ''
    12:24:04:540: Debug info: 'INF.cpp (12)'
    12:24:04:560: Reading config file : C:\WIN10_64\Config.xml
    12:24:04:580: Read Title Override : Intel x64 CherryTrail-T Driver Package
    12:24:04:640: Showing dialog: FINISH
    12:24:06:440: Dumping MSI properties (0 total)
    12:24:06:460: Exit code: 1603
    12:24:06:490: >>> Log End
  • Nate
    That appears to have worked. Thanks.
