Win 10 drivers issue
Massimo
New Member Posts: 2 ✭
Just installed Win 10 PRO version 1511 Build 10586.164 (x64 version). When I try to install your drivers WIN10_64 - Step_1-Chipset_and_peripherals through it's Setup.exe file it reports a failure message: "The setup program ended prematurely because of the following error: [string ID not found]"
What do you suggest to do?
Hi Maxmax,
Are you login as administrator?
You can try "Right click" on Setup.exe ->"Run as administrator" to run installation.
Or "Right click" on Setup.exe -> "Properties" -> "Security" to give current login account "Full control" permission. -
Same issue here. Get String ID Not Found error. Running as admin and I also tried copying theWIN10_64 folder to the desktop as was mentioned in another thread. Please provide guidance on how to install drivers for Windows 10 64-bit ASAP.
Here is my log file contents:
12:24:01:577: >>> Log start
12:24:01:587: Core version: 2.0.5
12:24:01:597: Setup version: 2.0.0.11
12:24:01:607: Command line: "C:\WIN10_64\Setup.exe"
12:24:01:617: OS data: 6-2-1-0 64-bit
12:24:01:627: System up time: 576 sec
12:24:01:637: Current UI language: 0409
12:24:01:647: Language folder: C:\Users\UP_LOC~1\AppData\Local\Temp\IIFCD99.tmp
12:24:01:717: Found C:\Users\UP_LOC~1\AppData\Local\Temp\IIFCD99.tmp\en-US\IntelCommon.dll. Lang 0409. Rank 3
12:24:01:767: Relaunching setup as elevated
12:24:03:920: Dumping MSI properties (0 total)
12:24:03:940: Exit code: 0
12:24:03:950: >>> Log End
12:24:03:990: >>> Log start
12:24:04:000: Core version: 2.0.5
12:24:04:020: Setup version: 2.0.0.11
12:24:04:040: Command line: "C:\WIN10_64\Setup.exe"
12:24:04:050: OS data: 6-2-1-0 64-bit
12:24:04:070: System up time: 579 sec
12:24:04:090: Current UI language: 0409
12:24:04:100: Language folder: C:\Users\UP_LOC~1\AppData\Local\Temp\IIFD72F.tmp
12:24:04:180: Found C:\Users\UP_LOC~1\AppData\Local\Temp\IIFD72F.tmp\en-US\IntelCommon.dll. Lang 0409. Rank 3
12:24:04:230: Package version: 2.0.1.14
12:24:04:250: Installed version: <Not installed>
12:24:04:270: This is a clean install
12:24:04:280: Setup mode: Installation
12:24:04:300: Looking for OS: 6.0
12:24:04:320: OS check passed
12:24:04:340: .NET not required, skipping requirement check
12:24:04:360: Driver source is C:\WIN10_64\Drivers
12:24:04:380: Using folder 'C:\WIN10_64\Drivers' as the driver source
12:24:04:400: Scanning all active devices
12:24:04:460: E Win32 exception occurred!!
12:24:04:480: Error code: 0xE0000100 (-536870656)
12:24:04:500: Error text: ''
12:24:04:520: Extended error text: ''
12:24:04:540: Debug info: 'INF.cpp (12)'
12:24:04:560: Reading config file : C:\WIN10_64\Config.xml
12:24:04:580: Read Title Override : Intel x64 CherryTrail-T Driver Package
12:24:04:640: Showing dialog: FINISH
12:24:06:440: Dumping MSI properties (0 total)
12:24:06:460: Exit code: 1603
12:24:06:490: >>> Log End -
Could you help to try this ?
https://www.dropbox.com/s/ktslq4x9fggr4oc/Win10_64.rar?dl=0 -
That appears to have worked. Thanks.
- 68 Product News - New Product/Product Change Notice/ End-of-life
- 3.5K UP Products
- 23 UP 7000
- 15 UP Squared Pro 7000
- 24 UP Xtreme i11
- 141 UP Xtreme
- 223 UP Core
