Installation of WIN10_32 - Step_1 drivers fails
Steve
New Member Posts: 3 ✭
I installed the 32 bit bios in order to install 32 bit windows 10. After installation I tried installing the MS WINDOWS 10 32BIT DRIVERS PACKAGE. I copied the driver folder to my desktop after the installation failed a couple of time, because I saw that was an issue with the 64 bit driver file. But I continue to have the same failure. Can any help with the reason? I have included the log file.
Steve
Steve
There were no issues for me with the 64 bit drivers. I'm using win 10 desktop in my workshop with one of these and its perfect for the job!
I didn't have any issues with the 64 bit drivers either. It only after I switched to the the 32 bit system did the issue occur.
The driver on below link may help:
http://www.aaeon.com/en/p/up-board-computer-board-for-professional-makers#downloads -
Thanks! I'll give that a try.
I am also facing the same issue as described. Please see attached log.
I am having the exact same problem. The installation fails with the error in the log:
Unable to pre-install driver file: C:\Users\Myname\Desktop\WIN10_32\Drivers\Graphics\igdlh.inf - error code 3758097155
I have pulled the WIN10_32 folder out of the "Step_1..." folder thinking that could be the issue, but no luck.
I'm dead in the water at this point.
Mike -
Could you help to try this package?
https://www.dropbox.com/s/rb3fnh13kgef5u6/Win10_32.rar?dl=0 -
The installation of that driver package installed successful, thanks.
In the same RAR file there is also a folder with a dummy driver, that 'installs' all-but-one unknown device. -
Do you mean here is sill one unknown device?
Do you mean here is still one unknown device?
Yes, there is an Unknown device listed below Other devices in Device Manager. When I open properties of the Unkown device the location is listed as: "on Intel (R) Serial IO I2C ES Controller". But, the UP board functions OK from what I can see.
In my case, I can 'install' all unknown device with dummy driver.
This extra unknown device may produced by old driver.
Would you mind to reinstall Windows and reinstall driver? -
Add some information:
If you have 'Bridge Device' with exclamation mark, please try to update your windows 10 then the driver will be installed.
(Via 'windows icon' -> 'Settings' -> 'Update & Security' -> 'Update')
Or enter 'device manager', to manually install bridge device driver through internet.
Please 'Right click' on 'Bridge device' -> 'Update Driver Software' -> 'Search automatically for updated driver software' to install.
About four 'unknown device', they can be installed with dummy driver.
