7" touchscreen case compatibility
Joost Boere
New Member Posts: 9 ✭
I didn't realise the 7" touchscreen needs some assembly and a case. Is it compatible with cases like this one? https://www.sossolutions.nl/7-touchscreen-sos-standaard-doorzichtig. The manufacturers website is down by the way, so I can't check there: www.futurelabs.asia.
Hi Milmoor,
From sossolution website, I can't see the size of the case. Normally we say 7" is the size of active area, every panel has different non-active area in the edge frame, so it is difficult to say. Here you can find more information about dimension of 7" display. You will need to find a case to fit this dimension. Thanks!
- 292 All Categories
- 104 Announcements & News
- 181 Welcome Developers!
- 20 Tech Updates
- 411 UP Products
- UP 4000
- 12 UP Xtreme i11
- 21 UP Squared 6000
- 40 UP Squared Pro
- 132 UP Xtreme
- 797 UP Squared
- 86 UP Core Plus
- 41 UP AI Edge
