7" touchscreen case compatibility
Joost Boere
Joost Boere New Member Posts: 9 ✭
edited August 2016 in Peripherals
I didn't realise the 7" touchscreen needs some assembly and a case. Is it compatible with cases like this one? https://www.sossolutions.nl/7-touchscreen-sos-standaard-doorzichtig. The manufacturers website is down by the way, so I can't check there: www.futurelabs.asia.
  • Aling
    Hi Milmoor,
    From sossolution website, I can't see the size of the case. Normally we say 7" is the size of active area, every panel has different non-active area in the edge frame, so it is difficult to say. Here you can find more information about dimension of 7" display. You will need to find a case to fit this dimension. Thanks!
