Android .img on the upboard
Ahmed
Posts: 3 ✭
Hi everyone,
I'm trying to flash Android on my upboard but I can't find the .img file to flash on the website.
Is Android isn't available on this board yet?
If it's already available can you provide me a link to this file?
Many thanks in advance!
Ahmed
Ahmed
Hi ,
At this moment, we only have beta version Android for download for beta tester. You can try from
here.
This image only enable GPIO in 40-pins not others, you may see the release note in the image file for more information. -
Hi thank you for the reply.
Does i2c works ?
Thank you in advance. -
The following functions are not working yet: We still keep working on the enabling.
1. USB USB OTG client mode doesn ’t work.
2. MIPI DSI and CSI doesn't work.
3. I2doesn't work.
4. I2S doesn't work.
5. SPI doesn't work.
6. PWM doesn't work.
7. UART doesn't work. -
When will there be an Android image with i2c and GPIO fully functional?
Thank you -
At this moment, we don't have specific time frame for I2C. For GPIOs, they are fully functional now.
Hi there,
I have the Android image installed but I get a "There was a problem parsing the package" error when trying to install any APK from File Manager. I have enabled install from unknown sources.
What am I doing wrong? -
What is the status about Android support?
Where can I get the latest image? -
You can download the image here https://up-community.org/downloads/android
But some I/O ports are not enabled, they are required to be paired with specific device, there are no general drivers for those I/O. -
thanks.
that page says: "No releases were found" -
I just checked the link is valid.https://up-community.org/downloads/android/android-android-6-0-beta1
Excuse me, but I can not see any download links. There is a note: "No files were found"
Are you able to download it now? -
I guess I might know the problem. The link is still not available for the public, we will enable it.
Please come back to check tomorrow. Sorry for the inconvenience. -
OK, thanks. I will check again tomorrow
Hello AlingWu,
I still can not see any files. Can you please enable public access?
bye -
....still not there
Could we please get an update on this? -
It should, be there now. SORRY!:-)
thank you, I can download it now.
What is the latest status about this image? What works, and what doesn't work? -
You will find the information in the release note, which is including in the download.
