Active cooler
Marcello
New Member Posts: 156 ✭
in Peripherals
Hi, I received boards and active coolers. However no instructions are included on how to install and connect it. Is it supposed to draw power from the gpio connector? In the CPLD connector I see also a fan pwm pin, except that this cooler does not have pwm control.
Could you please clarify? Thank you.
Please check here for SOP to replace the cooler. We will soon upload it to the "Documentation"area.
If there is anything unclear, please let us know. Thanks![ul]
[li][/li]
[li][/li]
[/ul] -
The document doesn't say if the fan is PWM or not. Does it run at full speed all the time?
Well... with two wires only and connected to 5V / GND it's an easy guess...
Yes true. Wasn't sure if they were doing any PWM on the 5v somehow, or even just activating it at a threshold temp.
The fan will be running at full speed all the time. Based on our test, it is very quiet.
We would like to have 4-wire fan, so that we can control the fan to turn on when it is needed, however, there is no standard product in the market at this moment.
If you happen to know any 4-wire miniature fan, we will be happy to test. -
hello pourqoui it is not provided the basic up really very hot
and it is expensive in the shop you speak gift for late July 14 ....... -
Hi gat,
I don't understand your message. Can you rephase it again ? Thanks! -
hello you are talking about a gift for the delay in delivery would be well
Hi gat, Sorry, I still can not understand your message very well. If it is about the active cooler, the active cooler is an optional accessory, not a gift. I am afraid there is some misunderstanding. You can always purchase the cooler at UP shop.
I thought ungeste be made for late shipments
I always expect the case in plasique
the sink is 24 dollard tax included I find expensive
principally made that the card heats up quicklyje croyait que ungeste serait fait pour les envois tardif
j attend toujours le boitier en plasique
le dissipateur vaut 24 dollard taxe incluse je trouve cher
surtous que la carte chauffe vite -
AlingWu wrote:Please check here for SOP to replace the cooler. We will soon upload it to the "Documentation"area.
[li][/li]
[li][/li]
[/ul]
Following your instructions I installed the active cooler. Conceptually easy, a bit scary though as at some point I was afraid of ripping the chips off the board....
I must say it is quiet and it does indeed Keep the board much cooler. -
Ok, finally got my board with the active cooler. Installed the heatsink/fan, but I'm utterly confused on how to hook up the connector... The instructions say to hook it to the bottom 2 pins on CN34.... That SHOULD be +5 and GND, but my board is missing the +5 pin!!! W.T.F. ???
NOT a happy camper!!! -
What do you mean by saying "no 5V pin"? physical missing pin? or no +5V voltage?
Correct. No physical pin in the lower left position on that header block. I have 5 pins on the left column, 6 on the right. Wtf???
If I have to I'll just snip the connector on the fan and replace it with one to use off the gpio 5V and GND but a bit mad that I'd have to hack it like that. -
There is an exchange SOP in the shop. http://up-shop.org/up-peripherals/64-active-cooler-fan-for-the-up-board.html
We will put this SOP in community soon.
If there is anything unclear in this SOP, please let us know. thanks! -
so will my 4gb/32gb upboard throttle without this playing games?
Hi jimdomandroid,
If the game takes a lot of CPU & GPU resources,such as 3D game, I will recommend to have a cooler. -
Thanks for starting this thread.
I had the same concern with pulling the chips off the board.
I got to use the fancy electronics tweezers I just bought to connect the power! -
Ok, correction... The pin was there, it was just so bent that it looked like it wasn't. Was showing the board off to my local robotics club this morning. One of the other members looked at it and was able to see the other pins (Damn my old person eyes!) and we were able to bend it back and attach the fan to it. Fan now works...
Glad you got that resolved. It's too bad that your pin was bent.
I know what you mean by "old person eyes". I had to use tweezers and a magnifying glass to connect mine. -
mkopack wrote:Ok, correction... The pin was there, it was just so bent that it looked like it wasn't. Was showing the board off to my local robotics club this morning. One of the other members looked at it and was able to see the other pins (Damn my old person eyes!) and we were able to bend it back and attach the fan to it. Fan now works...
- 105 Announcements & News
- 55 Product News - New Product/Product Change Notice/ End-of-life
- 184 Welcome Developers!
- 55 Unboxing & Project Sharing
- 32 Tech Updates
- 660 UP Products
- 1 UP 7000
- UP Squared i12
- 8 UP Xtreme i12
- 9 UP Squared Pro 7000
- 18 UP Squared V2
- 54 UP 4000
- 24 UP Xtreme i11
- 35 UP Squared 6000
- 58 UP Squared Pro
- 142 UP Xtreme
- 834 UP Squared
- 89 UP Core Plus
- 222 UP Core
- 44 UP AI Edge
- 215 Starter Kits & Peripheral
