How to tell an innovator board?
zuzzurro
zuzzurro Posts: 15 ✭✭
edited February 2023 in UP Squared BIOS & FPGA
If I'm not wrong the BIOS documentation for version 1.8 does not mention not to flash it on innovator boards, so I went ahead and flashed my up2 with and it still works.
In the documentation you use the term "EVT2" for Innovator's board. Where can one find the version of the board? Where does EVT2 come from? Let's imagine that I buy a used up2 and I want to upgrade the BIOS, how do I know whether it's safe or not?
  • zuzzurro
    I understand the question is probably silly, but would it be possible to get some sort of an answer @DCleri , @rogertsai(AAEON) , @camillus , @FredyHsu ?
  • Wilbert
    Wilbert Posts: 168 ✭✭✭
    Hi Sir,
    If possible, please provide an overall photo.
    Including the top view of the M/B and the photo of the BIOS version.
    It is convenient for me to provide suggestions here.
    Wilbert Lee.
  • Wilbert
    Hi Sir,
    Normally, there is no problem with BIOS upgrades, but there are too many BIOS upgrades, and many settings may be adjusted. It is recommended to reinstall your operating system after the update to avoid unexpected problems.
    Wilbert Lee
    AAEON Application Engineer
  • zuzzurro
    Sorry for the delay. I had not seen your reply. Is this enough?
  • zuzzurro
    One more time... can you tell me if the board in the picture I posted above is an innovator board?
    Much appreciated..
