UBUNTU 20.04.5 Error When i try to install
zarph
zarph New Member Posts: 8 ✭
everytime i try to install UBUNTU 20.04.5, Give me This error can you help me?
  • KrissNC
    KrissNC New Member Posts: 31 ✭
    What is your / ? are you using lvm ? Usually it goes well, are you using a special disk ?
  • zarph
    i have done normal installation here.
    No i dont have other disk.
    some adicional information.
    i tried define the disk size like
    2gb for swap
    200mb for EFI
    7gb for /
    and the rest for home.(6bg+/-)
    And then i cant boot.. i just dont know why .
    The version of ubuntu is 20.04.5
    i have installed Windows 10 and worked just fine.
  • KrissNC
    I guess I would try "use the whole disk" (NOT using lvm)), and not size the different FS by yourself (I'm wondering is 200M is ok for UEFI), on my board, I let the defaults sizes (I didnt set them by hand)
  • zarph
    i try to install like you say, nothing change ..
    i cant install 18.04 or 20.04 only works 22.04 and on 22.04 i cant install that kernel :neutral:
  • zarph
    edited January 2023
    UPDATE: I managed to install Ubuntu 20.4.5.
    how?
    Installed on another computer and then made an image of that disk and installed the image to the UP4000 and it worked.
    But now I can't get or install Ubuntu kernel 5.4.0 from PPA on Ubuntu 20.04 some help plz?
    Btw have done the installation of UBUNTU server 20.4.5.
  • zarph
    Hello Guys, I found the solution!!
    So when i install the ubuntu 18 or 20 i need to install with out network cable.
    Is working..
