UBUNTU 20.04.5 Error When i try to install
everytime i try to install UBUNTU 20.04.5, Give me This error can you help me?
What is your / ? are you using lvm ? Usually it goes well, are you using a special disk ?
i have done normal installation here.
No i dont have other disk.
some adicional information.
i tried define the disk size like
2gb for swap
200mb for EFI
7gb for /
and the rest for home.(6bg+/-)
And then i cant boot.. i just dont know why .
The version of ubuntu is 20.04.5i have installed Windows 10 and worked just fine.
I guess I would try "use the whole disk" (NOT using lvm)), and not size the different FS by yourself (I'm wondering is 200M is ok for UEFI), on my board, I let the defaults sizes (I didnt set them by hand)
i try to install like you say, nothing change ..
i cant install 18.04 or 20.04 only works 22.04 and on 22.04 i cant install that kernel
UPDATE: I managed to install Ubuntu 20.4.5.
how?
Installed on another computer and then made an image of that disk and installed the image to the UP4000 and it worked.
But now I can't get or install Ubuntu kernel 5.4.0 from PPA on Ubuntu 20.04 some help plz?Btw have done the installation of UBUNTU server 20.4.5.
Hello Guys, I found the solution!!
So when i install the ubuntu 18 or 20 i need to install with out network cable.
Is working..
