How to password protect BIOS and allow boot without user input?
I am using an UP board (UP-CHT01-A10-0216) with BIOS version UPC1DM25. The device is meant to be deployed and function without any user input. We have Ubuntu server 20.04 LTS running and it is the only OS that should be booted. For IP protection, we wanted to prevent people from booting a live USB and copying the flash from the UP board. So we enable BIOS user password to protect access to the BIOS. When the BIOS user password is enabled, the device does not boot automatically into the OS even though the OS is the only option to boot into in the boot order configuration. It halts for BIOS password before the OS is booted - thus requiring user intervention.
Can you recommend a way around this to prevent access to BIOS but also boot without user input?
  • camillus
    camillus AAEON Posts: 188 mod
    Hi @yash ,
    This can be done with a modified custom BIOS, kindly write me via my email on my profile, I will put you in touch with my colleague to handle this.
  • pietvr
    pietvr New Member Posts: 2 ✭
    Hi, I have the same problem. The UpBoard (UP-CHT01-A20-0216-B10) will run unattended without keyboard attached. Don't want the system to ask for password before it boot.
    How can I get the custom BIOS?
    Piet
  • pietvr
    Hi, ignore my previous post. I re-installed the OS and it is booting now.
    Piet
