Problem with new UP2 Board with R2.2 firmware
I just received my second UP2 board with the E3950. It has R2.2 firmware. I cannot enable console redirection. Under redirection tab, I can enable redirection and set port speed but port still shows disabled (even after reset). The lower option for Console Redirection serial Port for Out-of-Band Management does not appear as it did in previous version (which is on older board that I have). Console redirection is required for my application.
