Regulatory Domain not recognized by the System
scoppola
New Member Posts: 2 ✭
i'm struggling with the Intel AC3165 wireless adapter shipped with Intel Up² .
I'd like to create an access point on 5GHZ channels but setting the Regulatory Domain with all methods I tried gives no result.
I have tried to:
- disable lar via: echo
"options iwlwifi lar_disable=Y" >> /etc/modprobe.d/iwlwifi.conf
- set te reg dom via
iw reg set IT
- edit the file /etc/default/crda with
REGDOMAIN=IT
The output of iw reg get
seems to be correct:
global country IT: DFS-ETSI (2400 - 2483 @ 40), (N/A, 20), (N/A) (5150 - 5250 @ 80), (N/A, 23), (N/A), NO-OUTDOOR, AUTO-BW (5250 - 5350 @ 80), (N/A, 20), (0 ms), NO-OUTDOOR, DFS, AUTO-BW (5470 - 5725 @ 160), (N/A, 26), (0 ms), DFS (5725 - 5875 @ 80), (N/A, 13), (N/A) (57000 - 66000 @ 2160), (N/A, 40), (N/A)
Despite that the iw list
command returns only not usable channels for 5Ghz frequencies:
... Band 1: ... Frequencies: * 2412 MHz [1] (20.0 dBm) * 2417 MHz [2] (20.0 dBm) * 2422 MHz [3] (20.0 dBm) * 2427 MHz [4] (20.0 dBm) * 2432 MHz [5] (20.0 dBm) * 2437 MHz [6] (20.0 dBm) * 2442 MHz [7] (20.0 dBm) * 2447 MHz [8] (20.0 dBm) * 2452 MHz [9] (20.0 dBm) * 2457 MHz [10] (20.0 dBm) * 2462 MHz [11] (20.0 dBm) * 2467 MHz [12] (20.0 dBm) (no IR) * 2472 MHz [13] (20.0 dBm) (no IR) Band 2: Capabilities: 0x11ee HT20/HT40 SM Power Save disabled RX HT20 SGI RX HT40 SGI TX STBC RX STBC 1-stream Max AMSDU length: 3839 bytes DSSS/CCK HT40 Maximum RX AMPDU length 65535 bytes (exponent: 0x003) Minimum RX AMPDU time spacing: 4 usec (0x05) HT Max RX data rate: 150 Mbps HT RX MCS rate indexes supported: 0-7 TX unequal modulation not supported HT TX Max spatial streams: 2 HT TX MCS rate indexes supported may differ VHT Capabilities (0x33807120): Max MPDU length: 3895 Supported Channel Width: neither 160 nor 80+80 short GI (80 MHz) SU Beamformee RX antenna pattern consistency TX antenna pattern consistency VHT RX MCS set: 1 streams: MCS 0-9 2 streams: not supported 3 streams: not supported 4 streams: not supported 5 streams: not supported 6 streams: not supported 7 streams: not supported 8 streams: not supported VHT RX highest supported: 0 Mbps VHT TX MCS set: 1 streams: MCS 0-9 2 streams: not supported 3 streams: not supported 4 streams: not supported 5 streams: not supported 6 streams: not supported 7 streams: not supported 8 streams: not supported VHT TX highest supported: 0 Mbps Bitrates (non-HT): * 6.0 Mbps * 9.0 Mbps * 12.0 Mbps * 18.0 Mbps * 24.0 Mbps * 36.0 Mbps * 48.0 Mbps * 54.0 Mbps Frequencies: * 5180 MHz [36] (22.0 dBm) (no IR) * 5200 MHz [40] (22.0 dBm) (no IR) * 5220 MHz [44] (22.0 dBm) (no IR) * 5240 MHz [48] (22.0 dBm) (no IR) * 5260 MHz [52] (20.0 dBm) (no IR, radar detection) * 5280 MHz [56] (20.0 dBm) (no IR, radar detection) * 5300 MHz [60] (20.0 dBm) (no IR, radar detection) * 5320 MHz [64] (20.0 dBm) (no IR, radar detection) * 5500 MHz [100] (22.0 dBm) (no IR, radar detection) * 5520 MHz [104] (22.0 dBm) (no IR, radar detection) * 5540 MHz [108] (22.0 dBm) (no IR, radar detection) * 5560 MHz [112] (22.0 dBm) (no IR, radar detection) * 5580 MHz [116] (22.0 dBm) (no IR, radar detection) * 5600 MHz [120] (22.0 dBm) (no IR, radar detection) * 5620 MHz [124] (22.0 dBm) (no IR, radar detection) * 5640 MHz [128] (22.0 dBm) (no IR, radar detection) * 5660 MHz [132] (22.0 dBm) (no IR, radar detection) * 5680 MHz [136] (22.0 dBm) (no IR, radar detection) * 5700 MHz [140] (22.0 dBm) (no IR, radar detection) * 5720 MHz [144] (disabled) * 5745 MHz [149] (13.0 dBm) (no IR) * 5765 MHz [153] (13.0 dBm) (no IR) * 5785 MHz [157] (13.0 dBm) (no IR) * 5805 MHz [161] (13.0 dBm) (no IR) * 5825 MHz [165] (13.0 dBm) (no IR) Supported commands: ...
I'm using Ubuntu server 20.04.3 (but I had the same issue with 18.04) installed following the guide [here] (https://github.com/up-board/up-community/wiki/Ubuntu_20.04) and everything went fine.
The output of uname -a
Linux intel-up-2 5.4.0-1-generic #0~upboard4-Ubuntu SMP Thu Sep 23 01:47:49 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
The ouput of lspci | grep 3165
04:00.0 Network controller: Intel Corporation Wireless 3165 (rev 81)
any helps ?
