Build Errors yocto poky linux(pyro)
Hideki
Hideki Posts: 3
I have been trying to build yocto poky linux(pyro) on host PC(ubuntus16.04.4 on VirtualBox).
But it has finished building with following errors ,so I could not get builded image.
ERROR: linux-intel-4.9.81+gitAUTOINC+a2dfb1610d_c249d8e0ca-r0.1 do_unpack: Fetcher failure: Fetch command export [...my environment variable...]; git -c core.fsyncobjectfiles=0 checkout -B yocto-4.9 a2dfb1610d9dad34652a3c27c6c9d8751ed67af6 failed with exit code 128, output:
fatal: reference is not a tree: a2dfb1610d9dad34652a3c27c6c9d8751ed67af6
ERROR: linux-intel-4.9.81+gitAUTOINC+a2dfb1610d_c249d8e0ca-r0.1 do_unpack: Function failed: base_do_unpack
ERROR: Logfile of failure stored in: /home/apn/poky/build/tmp/work/corei7-64-intel-common-poky-linux/linux-intel/4.9.81+gitAUTOINC+a2dfb1610d_c249d8e0ca-r0.1/temp/log.do_unpack.8177
ERROR: Task ([...my home directry path...]/poky/meta-intel/common/recipes-kernel/linux/linux-intel_4.9.bb:do_unpack) failed with exit code '1'
I have used following procedure for building yocto poky linux(pyoro):
git clone -b pyro git://git.yoctoproject.org/poky.git
cd poky
git clone -b pyro git://git.yoctoproject.org/meta-intel.git
git clone -b pyro git://git.openembedded.org/meta-openembedded
git clone -b pyro https://github.com/emutex/meta-up-board
TEMPLATECONF=meta-up-board/conf source oe-init-build-env
bitbake upboard-image-sato
Is threre any mistake or missing procedure in my procedure?
I would appreciate any sort of help with this issue.
