lgw connect () did not return success-UP Squared LoRA Edge IP68 (915Mhz)
I have followed the steps on a previous post ( https://forum.up-community.org/discussion/3920/solved-problem-with-bringing-lora-server-on-upsquared-edge-computer) to resolve the _lgw connect () did not return success _ issue but still I am getting the errors (OS- Ubuntu 18.04). I tried to reinstall the OS (downgrading to Ubuntu 16.04) now i am getting hardware errors. Please refer to the image attached
please help
Hello @gvnura
That error is strange, but please do not use Ubuntu 16.04 anymore.
You should install Ubuntu 18.04 as per our procedure (including our kernel): https://github.com/up-board/up-community/wiki/Ubuntu_18.04
Then install the SPI ACPI override: https://github.com/up-board/up-community/wiki/Pinout_UP2#spi-portsThen follow the procedure for the lora driver and packet forwarder but please review the configuration files and update to use the correct frequencies for the 915Mhz version:
https://github.com/AAEONAEU-SW/packet_forwarder/tree/master/lora_pkt_fwdEditing the global_conf.json file
also please use this as reference to update the global_conf.json for your specific location: https://github.com/TheThingsNetwork/gateway-conf
@gvnura
I share my test image with you for SPI to LoRa testing, click the link below to download the image file
2018-12-17-03-ip68gateway-img
Please unzip the image file and put the file to your USB drive, then use Clonezilla to restore the image
In Clonezilla, please choose "Expert mode" and enable "icds" and -k1 option. OS login password is 123456.How to test
Open linux terminal and test the commands belowcd /opt/ttn-geteway/lora_gateway/util_spi_stress
./util_spi_stressIf LoRA & SPI is working properly, you will see the messages like below
If you want to test the GPIO430 to reset LoRa, try the command below
echo 430 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio430/direction
echo 1 > /sys/class/gpio/gpio430/value
echo 0 > /sys/class/gpio/gpio430/valueNext, just change the config file to 915Mhz frequency
@DCleri @rogertsai(AAEON) I'm going to install Ubuntu on an AAEON AOIT-IP6801, Is Ubuntu 18.04 preferred over Ubuntu 20.04? Thanks!
@DCleri @rogertsai @Pratik_Kushwaha
While following the directions to install Ubuntu 18.04, when I execute:
I get the following error:
E: Aborting removal of the running kernel dpkg: error processing package linux-image-5.4.0-77-generic (--remove): installed linux-image-5.4.0-77-generic package pre-removal script subprocess returned error exit status 1 dpkg: too many errors, stopping Errors were encountered while processing: linux-image-5.4.0-77-generic Processing was halted because there were too many errors.
I'm not able add the AAEON kernel update and rebooting results in
Alert! /dev/mapper//ubuntu--vg-ubuntu--lv does not exist. Dropping to a shell!
I see the same behavior if I try to install Ubuntu 20.04 following the directions from the Wiki. I'm pretty much dead in the water at this point. I've successfully setup a AOIT-IP6801 in the past following the instructions for Ubuntu 16.04. Ideally, I would make the jump to Ubuntu 20.04.
Any advice on how to proceed?
@gerfen
Have you tried to reinstall your ubuntu OS with ISO below, and then follow the steps from UP Wiki
https://releases.ubuntu.com/bionic/ubuntu-18.04.5-desktop-amd64.iso
or 20.04.2
https://releases.ubuntu.com/20.04/ubuntu-20.04.2.0-desktop-amd64.iso -
@rogertsai(AAEON) I followed the instructions for Ubuntu 18.04 and Ubuntu 20.04 . I pretty much had the same issues for both distros. FWIW, using the instructions for Ubuntu 16.04 I was able to successfully get my gateway configured. Have the instructions for 18.04 and 20.04 been tested or just copied from 16.04 and modified? From my experience they do not work.
What the step you do when you execute the command below to remove all the generic installed kernel
In general, you should hit the Y key to continue the operation and then choose as the answer when you see the message about kernel removal
BTW, what’s BIOS version you use?
@rogertsai(AAEON) I'm just getting back around to trying to install Ubuntu 18.04. My BIOS version is
AIOT-IP6801 R1.3 (AP68AM13) (09/28/2018)
Note that I have screenshots from installing Ubuntu if those would be helpful. Here are my full logs from following the instruction in the Wiki:
*******************************:~$ sudo add-apt-repository ppa:aaeon-cm/5.4-upboard UP kernel 5.4.0-1 support More info: https://launchpad.net/~aaeon-cm/+archive/ubuntu/5.4-upboard Press [ENTER] to continue or Ctrl-c to cancel adding it. Hit:1 http://us.archive.ubuntu.com/ubuntu bionic InRelease Get:2 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB] Get:3 http://ppa.launchpad.net/aaeon-cm/5.4-upboard/ubuntu bionic InRelease [15.9 kB] Get:4 http://us.archive.ubuntu.com/ubuntu bionic-backports InRelease [74.6 kB] Get:5 http://us.archive.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB] Get:6 http://ppa.launchpad.net/aaeon-cm/5.4-upboard/ubuntu bionic/main amd64 Packages [6008 B] Get:7 http://ppa.launchpad.net/aaeon-cm/5.4-upboard/ubuntu bionic/main Translation-en [3944 B] Fetched 278 kB in 2s (127 kB/s) Reading package lists... Done gerfen@evolution_outdoor_2:~$ *******************************:~$ sudo apt update Hit:1 http://us.archive.ubuntu.com/ubuntu bionic InRelease Get:2 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB] Hit:3 http://ppa.launchpad.net/aaeon-cm/5.4-upboard/ubuntu bionic InRelease Get:4 http://us.archive.ubuntu.com/ubuntu bionic-backports InRelease [74.6 kB] Get:5 http://us.archive.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB] Fetched 252 kB in 1s (190 kB/s) Reading package lists... Done Building dependency tree Reading state information... Done 65 packages can be upgraded. Run 'apt list --upgradable' to see them. *******************************:~$ sudo apt-get autoremove --purge 'linux-.*generic' update-initramfs: deferring update (trigger activated) Removing intel-microcode (3.20210608.0ubuntu0.18.04.1) ... update-initramfs: deferring update (trigger activated) Removing iucode-tool (2.3.1-1) ... Removing thermald (1.7.0-5ubuntu5) ... Removing libdbus-glib-1-2:amd64 (0.110-2) ... Removing linux-headers-generic (4.15.0.147.134) ... Removing linux-headers-4.15.0-147-generic (4.15.0-147.151) ... Removing linux-headers-4.15.0-147 (4.15.0-147.151) ... Removing linux-modules-extra-4.15.0-147-generic (4.15.0-147.151) ... Removing linux-image-4.15.0-147-generic (4.15.0-147.151) …
E: Aborting removal of the running kernel dpkg: error processing package linux-image-4.15.0-147-generic (--remove): installed linux-image-4.15.0-147-generic package pre-removal script subprocess returned error exit status 1 dpkg: linux-modules-4.15.0-147-generic: dependency problems, but removing anyway as you requested: linux-image-4.15.0-147-generic depends on linux-modules-4.15.0-147-generic. Removing linux-modules-4.15.0-147-generic (4.15.0-147.151) ... Errors were encountered while processing: linux-image-4.15.0-147-generic E: Sub-process /usr/bin/dpkg returned an error code (1) *******************************:~$ sudo apt-get install linux-generic-hwe-18.04-5.4-upboard Reading package lists... Done Building dependency tree Reading state information... Done You might want to run 'apt --fix-broken install' to correct these. The following packages have unmet dependencies: linux-generic-hwe-18.04-5.4-upboard : Depends: linux-image-generic-hwe-18.04-5.4-upboard (= 5.4.0.1.5000~upboard2) but it is not going to be installed Depends: linux-headers-generic-hwe-18.04-5.4-upboard (= 5.4.0.1.5000~upboard2) but it is not going to be installed linux-image-4.15.0-147-generic : Depends: linux-modules-4.15.0-147-generic but it is not going to be installed E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
You should select No on the question "Abort Kernel Removal" otherwise it won't work
@DCleri That was indeed the issue. It would be very helpful if the WiKi instructions (both Ubuntu 18.04 and Ubuntu 20.04) included this piece of information. That would have saved me many hours of banging my head against a wall.
Also it might be a good idea to include a step for running the spi_enable scripts for folks trying to use SPI.
Thanks @gerfen for the suggestions, we will make it more clear in our wiki to avoid such problems in the future.
About the spi_enable, we already provide steps in our wiki but, as the acpi override are board specific, we include the instructions in the pinout page of each board, instead of the generic Ubuntu installation page.
Please check out the spi_enable for UP Squared: https://github.com/up-board/up-community/wiki/Pinout_UP2#spi-ports
