lgw connect () did not return success-UP Squared LoRA Edge IP68 (915Mhz)
gvnura
gvnura New Member Posts: 1
edited July 2021 in UP Squared Linux
I have followed the steps on a previous post ( https://forum.up-community.org/discussion/3920/solved-problem-with-bringing-lora-server-on-upsquared-edge-computer) to resolve the _lgw connect () did not return success _ issue but still I am getting the errors (OS- Ubuntu 18.04). I tried to reinstall the OS (downgrading to Ubuntu 16.04) now i am getting hardware errors. Please refer to the image attached
please help
    Hello @gvnura
    That error is strange, but please do not use Ubuntu 16.04 anymore.
    You should install Ubuntu 18.04 as per our procedure (including our kernel): https://github.com/up-board/up-community/wiki/Ubuntu_18.04
    Then install the SPI ACPI override: https://github.com/up-board/up-community/wiki/Pinout_UP2#spi-ports
    Then follow the procedure for the lora driver and packet forwarder but please review the configuration files and update to use the correct frequencies for the 915Mhz version:
    https://github.com/AAEONAEU-SW/packet_forwarder/tree/master/lora_pkt_fwd
    Editing the global_conf.json file
    also please use this as reference to update the global_conf.json for your specific location: https://github.com/TheThingsNetwork/gateway-conf
  • rogertsai(AAEON)
    edited July 2021
    @gvnura
    I share my test image with you for SPI to LoRa testing, click the link below to download the image file
    2018-12-17-03-ip68gateway-img
    Please unzip the image file and put the file to your USB drive, then use Clonezilla to restore the image
    In Clonezilla, please choose "Expert mode" and enable "icds" and -k1 option. OS login password is 123456.
    How to test
    Open linux terminal and test the commands below
    cd /opt/ttn-geteway/lora_gateway/util_spi_stress
    ./util_spi_stress
    If LoRA & SPI is working properly, you will see the messages like below
    If you want to test the GPIO430 to reset LoRa, try the command below
    echo 430 > /sys/class/gpio/export
    echo out > /sys/class/gpio/gpio430/direction
    echo 1 > /sys/class/gpio/gpio430/value
    echo 0 > /sys/class/gpio/gpio430/value
    Next, just change the config file to 915Mhz frequency
  • gerfen
    gerfen New Member Posts: 31 ✭✭
    edited July 2021
    @DCleri @rogertsai(AAEON) I'm going to install Ubuntu on an AAEON AOIT-IP6801, Is Ubuntu 18.04 preferred over Ubuntu 20.04? Thanks!
  • gerfen
    @DCleri @rogertsai @Pratik_Kushwaha
    While following the directions to install Ubuntu 18.04, when I execute:
    I get the following error:
    E: Aborting removal of the running kernel
    dpkg: error processing package linux-image-5.4.0-77-generic (--remove):
     installed linux-image-5.4.0-77-generic package pre-removal script subprocess returned error exit status 1
    dpkg: too many errors, stopping
    Errors were encountered while processing:
    Processing was halted because there were too many errors.
    I'm not able add the AAEON kernel update and rebooting results in
    Alert! /dev/mapper//ubuntu--vg-ubuntu--lv does not exist.  Dropping to a shell!
    I see the same behavior if I try to install Ubuntu 20.04 following the directions from the Wiki. I'm pretty much dead in the water at this point. I've successfully setup a AOIT-IP6801 in the past following the instructions for Ubuntu 16.04. Ideally, I would make the jump to Ubuntu 20.04.
    Any advice on how to proceed?
  • rogertsai(AAEON)
    @gerfen
    Have you tried to reinstall your ubuntu OS with ISO below, and then follow the steps from UP Wiki
    https://releases.ubuntu.com/bionic/ubuntu-18.04.5-desktop-amd64.iso
    or 20.04.2
    https://releases.ubuntu.com/20.04/ubuntu-20.04.2.0-desktop-amd64.iso
  • gerfen
    edited July 2021
    @rogertsai(AAEON) I followed the instructions for Ubuntu 18.04 and Ubuntu 20.04 . I pretty much had the same issues for both distros. FWIW, using the instructions for Ubuntu 16.04 I was able to successfully get my gateway configured. Have the instructions for 18.04 and 20.04 been tested or just copied from 16.04 and modified? From my experience they do not work.
  • rogertsai(AAEON)
    edited July 2021
    @gerfen
    What the step you do when you execute the command below to remove all the generic installed kernel
    In general, you should hit the Y key to continue the operation and then choose as the answer when you see the message about kernel removal
    BTW, what’s BIOS version you use?
  • gerfen
    edited July 2021
    @rogertsai(AAEON) I'm just getting back around to trying to install Ubuntu 18.04. My BIOS version is
    AIOT-IP6801 R1.3 (AP68AM13) (09/28/2018)
    Note that I have screenshots from installing Ubuntu if those would be helpful. Here are my full logs from following the instruction in the Wiki:
    *******************************:~$ sudo add-apt-repository ppa:aaeon-cm/5.4-upboard
     UP kernel 5.4.0-1 support
     More info: https://launchpad.net/~aaeon-cm/+archive/ubuntu/5.4-upboard
    Press [ENTER] to continue or Ctrl-c to cancel adding it.
    Hit:1 http://us.archive.ubuntu.com/ubuntu bionic InRelease
    Get:2 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
    Get:3 http://ppa.launchpad.net/aaeon-cm/5.4-upboard/ubuntu bionic InRelease [15.9 kB]
    Get:4 http://us.archive.ubuntu.com/ubuntu bionic-backports InRelease [74.6 kB]
    Get:5 http://us.archive.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
    Get:6 http://ppa.launchpad.net/aaeon-cm/5.4-upboard/ubuntu bionic/main amd64 Packages [6008 B]
    Get:7 http://ppa.launchpad.net/aaeon-cm/5.4-upboard/ubuntu bionic/main Translation-en [3944 B]
    Fetched 278 kB in 2s (127 kB/s)
    Reading package lists... Done
    gerfen@evolution_outdoor_2:~$
    *******************************:~$ sudo apt update
    Hit:3 http://ppa.launchpad.net/aaeon-cm/5.4-upboard/ubuntu bionic InRelease
    Fetched 252 kB in 1s (190 kB/s)
    Building dependency tree
    Reading state information... Done
    65 packages can be upgraded. Run 'apt list --upgradable' to see them.
    *******************************:~$ sudo apt-get autoremove --purge 'linux-.*generic'
    update-initramfs: deferring update (trigger activated)
    Removing intel-microcode (3.20210608.0ubuntu0.18.04.1) ...
    Removing iucode-tool (2.3.1-1) ...
    Removing thermald (1.7.0-5ubuntu5) ...
    Removing libdbus-glib-1-2:amd64 (0.110-2) ...
    Removing linux-headers-generic (4.15.0.147.134) ...
    Removing linux-headers-4.15.0-147-generic (4.15.0-147.151) ...
    Removing linux-headers-4.15.0-147 (4.15.0-147.151) ...
    Removing linux-modules-extra-4.15.0-147-generic (4.15.0-147.151) ...
    Removing linux-image-4.15.0-147-generic (4.15.0-147.151) …
    dpkg: error processing package linux-image-4.15.0-147-generic (--remove):
     installed linux-image-4.15.0-147-generic package pre-removal script subprocess returned error exit status 1
    dpkg: linux-modules-4.15.0-147-generic: dependency problems, but removing anyway as you requested:
     linux-image-4.15.0-147-generic depends on linux-modules-4.15.0-147-generic.
    Removing linux-modules-4.15.0-147-generic (4.15.0-147.151) ...
    E: Sub-process /usr/bin/dpkg returned an error code (1)
    *******************************:~$ sudo apt-get install linux-generic-hwe-18.04-5.4-upboard
    You might want to run 'apt --fix-broken install' to correct these.
    The following packages have unmet dependencies:
     linux-generic-hwe-18.04-5.4-upboard : Depends: linux-image-generic-hwe-18.04-5.4-upboard (= 5.4.0.1.5000~upboard2) but it is not going to be installed
                                           Depends: linux-headers-generic-hwe-18.04-5.4-upboard (= 5.4.0.1.5000~upboard2) but it is not going to be installed
     linux-image-4.15.0-147-generic : Depends: linux-modules-4.15.0-147-generic but it is not going to be installed
    E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
    You should select No on the question "Abort Kernel Removal" otherwise it won't work
  • gerfen
    @DCleri That was indeed the issue. It would be very helpful if the WiKi instructions (both Ubuntu 18.04 and Ubuntu 20.04) included this piece of information. That would have saved me many hours of banging my head against a wall. :smile:
    Also it might be a good idea to include a step for running the spi_enable scripts for folks trying to use SPI.
    Thanks @gerfen for the suggestions, we will make it more clear in our wiki to avoid such problems in the future.
    About the spi_enable, we already provide steps in our wiki but, as the acpi override are board specific, we include the instructions in the pinout page of each board, instead of the generic Ubuntu installation page.
    Please check out the spi_enable for UP Squared: https://github.com/up-board/up-community/wiki/Pinout_UP2#spi-ports
