RTC Quality
SeanI
SeanI New Member Posts: 4 ✭
Hi, would like to use the UpBoard for generating output with accurate timestamps. The idea is to use GPS based time source into an onboard NTP server to update the local time. However, when I remove the GPS feed I would like to understand the possible clock drift.
Does anybody know the part numbers for the RTC so I can investigate its quality.
