UP Squared (UP2) - How to use exHAT's GPIOs ?
Hello Everyone,
I am trying to use the ExHat-60 Pin (the simpliest use of it) of the Up2 and I am kind of lost on what I need to do to control any of those Pin and turn on a LED for example.
I found info there : https://wiki.up-community.org/Pinout_UP2 to be able to use the 40-Pin HAT (not tested yet) but it does not seems as easy to use the exHAT Connector. (or I didn't get how to use the exHAT Pinout array)
If anyone can point me the right direction on which file to modify to add the exHAT-60 Pin spec (an equivalent to a board.h ?) or the library to download to use the exHAT, it would be appreciated.
Also If anyone succeded on how to use the exHAT, I am interested on How you did it.
Thanks to all who read this.
Thom
I too really want to know how to do this!
Hi All,
I am working on UP2 with Ubuntu 18.04 by kernel update. The uname -a returns the following output
$uname -a
"Linux intel-UP-APL01 4.15.0-37-generic #40~upboard07-Ubuntu SMP Tue Apr 7 14:30:14 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux"$mraa-gpio list
03 I2C_SDA: GPIO I2C
05 I2C_SCL: GPIO I2C
07 GPIO4: GPIO
08 UART_TX: GPIO UART
10 UART_RX: GPIO UART
11 UART_RTS: GPIO UART
12 I2S_CLK: GPIO
13 GPIO27: GPIO
15 GPIO22: GPIO
16 PWM3: GPIO PWM
18 GPIO24: GPIO
19 SPI0_MOSI: GPIO SPI
21 SPI0_MISO: GPIO SPI
22 GPIO25: GPIO
23 SPI0_CLK: GPIO SPI
24 SPI0_CS0: GPIO SPI
26 SPI0_CS1: GPIO SPI
27 ID_SD: GPIO I2C
28 ID_SC: GPIO I2C
29 GPIO5: GPIO
31 GPIO6: GPIO
32 PWM0: GPIO PWM
33 PWM1: GPIO PWM
35 I2S_FRM: GPIO
36 UART_CTS: GPIO UART
37 GPIO26: GPIO
38 I2S_DIN: GPIO
40 I2S_DOUT: GPIOI would like to know any sample program which can access GPIO pins. It will be very helpul if we could have LED blink program.
Request your help in this. Thank you very much in advance.
Please refer to this wiki page for libMRAA with sample Python scripts for accessing GPIO and LEDs
https://github.com/up-board/up-community/wiki/MRAA -
the exHAT has not been enabled to be used out of the box, but only under specific project requests.
For normal use and development you have access to the standard 40pin as described in our wiki and libMRAA documentation.
If you need to use additional pins available on exHAT you can contact our shop/sales to discuss a new project.
