M.2 SSD not detected when M.2 Wifi card installed
I've been using an M.2 SSD in my Xtreme for a while, and it works great.
It is a Crucial MX500 500GB 2280, like this one:
https://www.amazon.com/Crucial-MX500-500GB-2280SS-Internal/dp/B077SQ8J1V
It is installed in the M-keyed slot (CN4).
I recently bought the M.2 2230 Wifi Kit for the Xtreme from your shop:
https://up-shop.org/new-m-2-2230-wifi-kit-for-up-squared-up-xtreme.html
but when it is installed in the E-key slot (CN3), the Xtreme system no longer detects my SSD in CN4.
How do I fix this? I need to use both devices!
  • rogertsai(AAEON)
    edited May 2021
    @razor1000
    I didn't see any issues with CN3 and CN4 using Transcend TS64GMTS800(SSD SATA) + Intel 9260 Wifi Kit, both are working fine
    Please check your m.2 key connection , or try to use another brand or model of the m.2 storage card for connection
  • razor1000
    razor1000 New Member Posts: 22
    @rogertsai(AAEON) said:
    @razor1000
    Is there an official list of supported SSDs? I need something bigger than 64GB, and I don't have time to buy another set of drives and return them if they don't work.
  • jayman
    jayman New Member Posts: 66 ✭✭
    Are you sure it's not just a matter of inserting the cards correctly? Is this behavior fully repeatable? Every time you remove the M.2 SATA card, the M.2 Wi-Fi card will work, and every time you install the M.2 SATA card the M.2 Wi-Fi card will not be recognized? That really doesn't make a lot of sense to me. I had a similar setup , albeit with a Wi-Fi card in the M.2 E-key slot, and an NVMe SSD (not SATA) in the M.2 M-key slot. They both worked fine no problem.
  • rogertsai(AAEON)
    Here's the SSD models we used in our M.2 2280 test
    1. Transcend TS32GMTS800
    2. Transcend TS64GMTS800
    3. Transcend TS128GMTS800
    4. Transcend TS256GMTS800
  • razor1000
    No, I haven't tried all the combinations, but the SSD model I'm using has worked fine in 3 different systems when installed all by itself, and when I tried both the official wifi card from Up, along with the SSD, it didn't show up as detected in the BIOS. When I removed the wifi card, the SSD showed up like normal. I have another wifi card (same model). Maybe I'll try that one and see if the same thing happens.
    Hi @razor1000
    What PSU are you using?
  • razor1000
    @DCleri said:
    Hi @razor1000
    I'm using the stock 19V power supply from the shop:
    https://up-shop.org/up-xtreme-power-supply.html
