IEC 62368-1 / IEC 60950-1
Hi there, I'm looking for the test report for above mentioned IEC standards (safety) for the up squared board.
there is a report in the downloads area, but it's only for EMC standards. Can you help? Thanks a lot.
Best Answer
  • Aling
    Answer ✓
    IEC-60950-1 is for IT equipment but not mandatory for embedded computers. So we didn't certify IEC60950-1. ( IEC62368-1=IEC60950-1+ IEC60065, based on the same reason, we didn't certify it as well).
    It doesn't bring you any trouble if you want to use UP board for embedded purposes. Probably not ideal if you want to sell UP board to a consumer.
  • hubseb
    hubseb New Member Posts: 4 ✭
    Hi Aling, thanks for your quick reply! ok, that's a pity. Is it possible to get a datasheet of the used board material with UL number on it, or maybe a yellow card number? The 60335 we need to test our machine is looking mainly for fire testing and fire consistency. Thank you! Best regards
  • Aling
    Hi , Please reach out to info@up-board.org. We can provide a list of UL number of components we use on the boards.
