New Up Xtreme Edge Compute Enabling Kit not booting in Linux
Hello, I have just unboxed a new UP Xtreme Edge Compute Enabling Kit.
The contained quick start guide says: "the system will turn on automatically. you can log on into Ubuntu using the credentials devkit/devkit".
When I power up the system it runs always in the UEFI shell.
Is it supposed to have linux preinstalled?
When I go in the bios setup screen I do not see eMmc boot device.
Stefano
Hi Stefano,
Yes. For the enabling kit, the OS is pre-installed. Can you share the screen shot which you don't see eMMC?
BR
Aling -
Hi Aling,
I have attached the uefi shell I have after power on and the boot's options devices in the bios.
BR
Stefano -
I have the exact same problem.
How can I solve it? Should I try to reinstall ubuntu?
Thank you.Riccardo
Hi @morattos , @riccardo_s ,
Please apply for an RMA for the above UP Xtreme product.
You can request an RMA from UP Shop directly (check here, https://up-shop.org/cancellation-sales-return-doa-rma) if the purchase was made via our UP Shop.
If it was purchased from one of our distributors, you can process the RMA via their return services.Thanks,
Pratik -
Thank you @Pratik_Kushwaha for your response.
Unfortunately, I need to get the board up and running as soon as possible, and an RMA request would slow me down too much.
Is it possible to work around the problem somehow or is it a hardware flaw?
Thank you again,Riccardo
Hi @Pratik_Kushwaha, I proceeded with the RMA. I have received the product back and now it boots correctly using the emmc into the preinstalled UBUNTU
Stefano -
I have the problem where the screen comes up as in the first picture and just stays there not allowing me to go any further. Tried the DEL and nothing happened. Still not able to get past....powered up and down several times and no solution...help
hi @LAZ,
Camillus here, if I understand correctly, the screen you see is the UEFI BIOS shell. Do you already have an OS installed ? Please give more details. The screen comes up because UEFI shell is selected as boot priority in BIOS settings. I will suggest you type 'exit' when the screen comes up and it will boot into the OS. Let me know the outcome.
When I power up the system it runs always in the UEFI shell.Is it supposed to have linux preinstalled?
StefanoI'm having a similar problem. What should be done on this?
