step 1 of drivers install failed "system reboot is required to roll back changes made"
twingall1
twingall1 New Member Posts: 2 ✭
Rebooted but still the same.
here is part of the error log for cherry trail:
01:00:53:595: E Uninstalling drivers that were previously pre-installed by DriverPackagePreInstall...
01:00:53:595: E Setup aborted!
01:00:53:595: m_nCurrentIndex : 4
01:00:53:642: Showing dialog: FINISH
01:01:02:126: Dumping MSI properties (0 total)
01:01:02:141: Exit code: 1602
01:01:02:141: >>> Log End
trying to update the bios on someone's suggestion but not recognizing the fat32 usb drive i've prepared with latest bios..
any help would be greatly appreciated
  • cellprocesses
    cellprocesses New Member Posts: 5 ✭
    Im having the same issue, it appears theres an issue in installing the MSI portion of the drivers
  • twingall1
    24hours later and it appears not to matter in my case.
    Only using it to run a crypto wallet which i need to be open all the time.
    skipped step 1(cherry trail) and skipped step 3(dummy drivers)
    did all the other steps without issues.
