windows 10 suddenly wont boot on two boards.
hi,
i have 3 up core boards,
two of them suddenly stop booting.
when i power them on system goes into bios.
in OS IMAGE it seems to recognize the windows but when i send it to boot it just keeps going into bios.
did the 2 boards lost power suddenly before the problem appeared?
Please try to disconnect all the cables and then remove the RTC battery and re-plug it after few minutes. Then power on the boards again.
Is the issue still happening? -
yeah iv'e tried that on both boards and it didnt work.
yes the boards lost power because they were running of a bench power supply and were shut down by turning of the supply. -
@DCleri said:
did the 2 boards lost power suddenly before the problem appeared?Please try to disconnect all the cables and then remove the RTC battery and re-plug it after few minutes. Then power on the boards again.
Is the issue still happening?any other options?
If you plug a USB (the one with the Windows Installer) can it boot from there?
If so, please try the option to repair/recovery as the eMMC boot partition could be corrupted due to the power loss.
ill try to boot from a usb stick..
how do i go about with the other option repair/recovery? -
You may want to try the steps provided on Microsoft Community: https://answers.microsoft.com/en-us/windows/forum/windows_10-performance/repair-windows-10-using-usb-drive/35c9a8f8-dde5-4370-a8fe-5a84b9e00ebb
i tried using the boot from usb, and then after using disk clean with diskpart, it managed to reboot itself and work.
thank you.
