How to setup UP2 for Windows Debugging ?
Johann
Johann New Member Posts: 5 ✭
Hi all,
I am running Windows 10.0.18363 on UP2, and would like to connect to other Windows host PC for debugging.
I've follow the following link and tried connect with "10-pin connector CN7 (UART0)" with "3.3V FTDI Serial cable".
https://wiki.up-community.org/Serial_console
On UP2, I've set up the debug settings as below :
bcdedit /debug on
bcdedit /dbgsettings SERIAL DEBUGPORT:1 BAUDRATE:115200
But it doesn't seems to work with WinDbg. Does any one have similar experience on Windows debugging ? Should I use ethernet for Windows debugging on UP2 instead ?
Thanks !!
