notice
The addon with key CloudflareImageResize could not be found and will not be started.
#0 [internal function]: Vanilla\Logging\ErrorLogger::handleError(1024, 'The addon with ...', '/var/www/fronte...', 1121)
#1 /var/www/frontend-faf9efd150991e/library/Vanilla/AddonManager.php(1121): trigger_error('The addon with ...', 1024)
#2 /var/www/frontend-faf9efd150991e/bootstrap.php(538): Vanilla\AddonManager->startAddonsByKey(Array, 'addon')
#3 [internal function]: {closure}(Object(Vanilla\Utility\TracedContainer), Object(Vanilla\AddonManager), Object(Gdn_Request))
#4 /var/www/frontend-faf9efd150991e/vendor/vanilla/garden-container/src/Container.php(353): call_user_func_array(Object(Closure), Array)
#5 /var/www/frontend-faf9efd150991e/bootstrap.php(477): Garden\Container\Container->call(Object(Closure))
#6 /var/www/frontend-faf9efd150991e/index.php(28): require_once('/var/www/fronte...')
#7 {main} |
notice
Config "Garden.Cookie.Domain" is incompatible with the current host (forum.up-community.org vs ).
#0 [internal function]: Vanilla\Logging\ErrorLogger::handleError(1024, 'Config "Garden....', '/var/www/fronte...', 92)
#1 /var/www/frontend-faf9efd150991e/library/core/class.cookieidentity.php(92): trigger_error('Config "Garden....', 1024)
#2 /var/www/frontend-faf9efd150991e/library/core/class.cookieidentity.php(68): Gdn_CookieIdentity->init(Array)
#3 [internal function]: Gdn_CookieIdentity->__construct(NULL)
#4 /var/www/frontend-faf9efd150991e/vendor/vanilla/garden-container/src/Container.php(623): ReflectionMethod->invokeArgs(Object(Gdn_CookieIdentity), Array)
#5 /var/www/frontend-faf9efd150991e/vendor/vanilla/garden-container/src/Container.php(875): Garden\Container\Container->createSharedInstance('Identity', Array, Array)
#6 /var/www/frontend-faf9efd150991e/library/Vanilla/Utility/TracedContainer.php(33): Garden\Container\Container->createInstance('Identity', Array)
#7 /var/www/frontend-faf9efd150991e/vendor/vanilla/garden-container/src/Container.php(323): Vanilla\Utility\TracedContainer->createInstance('Identity', Array)
#8 /var/www/frontend-faf9efd150991e/library/core/class.gdn.php(268): Garden\Container\Container->getArgs('Identity', Array)
#9 /var/www/frontend-faf9efd150991e/library/core/class.auth.php(546): Gdn::factory('Identity')
#10 /var/www/frontend-faf9efd150991e/library/core/class.auth.php(50): Gdn_Auth->identity()
#11 /var/www/frontend-faf9efd150991e/vendor/vanilla/garden-container/src/Container.php(629): Gdn_Auth->__construct()
#12 /var/www/frontend-faf9efd150991e/vendor/vanilla/garden-container/src/Container.php(875): Garden\Container\Container->createSharedInstance('Authenticator', Array, Array)
#13 /var/www/frontend-faf9efd150991e/library/Vanilla/Utility/TracedContainer.php(33): Garden\Container\Container->createInstance('Authenticator', Array)
#14 /var/www/frontend-faf9efd150991e/vendor/vanilla/garden-container/src/Container.php(323): Vanilla\Utility\TracedContainer->createInstance('Authenticator', Array)
#15 /var/www/frontend-faf9efd150991e/vendor/vanilla/garden-container/src/Container.php(397): Garden\Container\Container->getArgs('Authenticator')
#16 /var/www/frontend-faf9efd150991e/bootstrap.php(622): Garden\Container\Container->get('Authenticator')
#17 /var/www/frontend-faf9efd150991e/index.php(28): require_once('/var/www/fronte...')
#18 {main} |
notice
#2 /var/www/frontend-faf9efd150991e/library/core/class.auth.php(547): Gdn_CookieIdentity->init()
#3 /var/www/frontend-faf9efd150991e/library/core/class.auth.php(50): Gdn_Auth->identity()
#4 /var/www/frontend-faf9efd150991e/vendor/vanilla/garden-container/src/Container.php(629): Gdn_Auth->__construct()
#5 /var/www/frontend-faf9efd150991e/vendor/vanilla/garden-container/src/Container.php(875): Garden\Container\Container->createSharedInstance('Authenticator', Array, Array)
#6 /var/www/frontend-faf9efd150991e/library/Vanilla/Utility/TracedContainer.php(33): Garden\Container\Container->createInstance('Authenticator', Array)
#7 /var/www/frontend-faf9efd150991e/vendor/vanilla/garden-container/src/Container.php(323): Vanilla\Utility\TracedContainer->createInstance('Authenticator', Array)
#8 /var/www/frontend-faf9efd150991e/vendor/vanilla/garden-container/src/Container.php(397): Garden\Container\Container->getArgs('Authenticator')
#9 /var/www/frontend-faf9efd150991e/bootstrap.php(622): Garden\Container\Container->get('Authenticator')
#10 /var/www/frontend-faf9efd150991e/index.php(28): require_once('/var/www/fronte...')
#11 {main} |
warning
Attempt to read property "UserID" on false
#0 /var/www/frontend-faf9efd150991e/plugins/PostCount/class.postcount.plugin.php(31): Vanilla\Logging\ErrorLogger::handleError(2, 'Attempt to read...', '/var/www/fronte...', 31)
#1 /var/www/frontend-faf9efd150991e/plugins/PostCount/class.postcount.plugin.php(23): PostCountPlugin->_AttachPostCount(Object(DiscussionController))
#2 [internal function]: PostCountPlugin->discussionController_authorInfo_handler(Object(DiscussionController), Array)
#3 /var/www/frontend-faf9efd150991e/library/Garden/EventManager.php(329): call_user_func_array(Array, Array)
#4 /var/www/frontend-faf9efd150991e/library/core/class.pluginmanager.php(838): Garden\EventManager->fire('DiscussionContr...', Object(DiscussionController), Array)
#5 /var/www/frontend-faf9efd150991e/library/core/class.pluginmanager.php(799): Gdn_PluginManager->callEventHandler(Object(DiscussionController), 'DiscussionContr...', 'AuthorInfo', 'Handler')
#6 /var/www/frontend-faf9efd150991e/library/core/class.pluggable.php(145): Gdn_PluginManager->callEventHandlers(Object(DiscussionController), 'DiscussionContr...', 'AuthorInfo')
#7 /var/www/frontend-faf9efd150991e/applications/vanilla/views/discussion/helper_functions.php(268): Gdn_Pluggable->fireEvent('AuthorInfo')
#8 /var/www/frontend-faf9efd150991e/applications/vanilla/views/discussion/comments.php(23): writeComment(Object(stdClass), Object(DiscussionController), Object(Gdn_Session), 3)
#9 /var/www/frontend-faf9efd150991e/applications/vanilla/views/discussion/index.php(96): include('/var/www/fronte...')
#10 /var/www/frontend-faf9efd150991e/library/core/class.controller.php(1030): include('/var/www/fronte...')
#11 /var/www/frontend-faf9efd150991e/library/core/class.controller.php(1694): Gdn_Controller->fetchView('', false, false)
#12 /var/www/frontend-faf9efd150991e/library/core/class.pluggable.php(246): Gdn_Controller->xRender()
#13 /var/www/frontend-faf9efd150991e/applications/vanilla/controllers/class.discussioncontroller.php(341): Gdn_Pluggable->__call('render', Array)
#14 /var/www/frontend-faf9efd150991e/applications/vanilla/controllers/class.discussioncontroller.php(423): DiscussionController->index(4234, 'x', 'p1')
#15 /var/www/frontend-faf9efd150991e/library/core/class.dispatcher.php(1055): DiscussionController->comment('11123')
#16 /var/www/frontend-faf9efd150991e/library/core/class.dispatcher.php(418): Gdn_Dispatcher->dispatchController(Object(Gdn_Request), Array)
#17 /var/www/frontend-faf9efd150991e/index.php(39): Gdn_Dispatcher->dispatch()
#18 {main} |
info
Could not find file 'microsoftaccount.css' in folder 'microsoftaccount'. |
info
Could not find file 'oauth2.css' in folder 'oauth2'. |
info
Could not find file 'custom_default.css' in folder ''. |
