Hello my UP not starting
kt7
kt7 New Member Posts: 1 ✭
my up does not start on the screen, nothing will show up
no light for pcb.
the power supply connected correctly the other up is working properly
  • Corplite
    Corplite New Member Posts: 1 ✭
    edited February 2020
    I think one of your units may simply be DoA. Unfortunately, I have the exact same problem, however do not have a second unit to compare it with. I have checked for basic shorts to ground, and voltage levels where I can, but without access to a schematic & board-view file, progress is extremely slow as you're reverse engineering an extremely complex and dense board. (so in many cases have to simply guess at what's happening on invisible layers.
  • rogertsai(AAEON)
    @kt7
    Try to remove the cmos battery to reset the bios, if it's still not working, you can apply for RMA
