Hello my UP not starting
kt7
New Member Posts: 1 ✭
my up does not start on the screen, nothing will show up
no light for pcb.
the power supply connected correctly the other up is working properly
I think one of your units may simply be DoA. Unfortunately, I have the exact same problem, however do not have a second unit to compare it with. I have checked for basic shorts to ground, and voltage levels where I can, but without access to a schematic & board-view file, progress is extremely slow as you're reverse engineering an extremely complex and dense board. (so in many cases have to simply guess at what's happening on invisible layers.
@kt7
Try to remove the cmos battery to reset the bios, if it's still not working, you can apply for RMA
- 105 Announcements & News
- 185 Welcome Developers!
- 49 Tech Updates
- 693 UP Products
- 11 UP 7000
- 10 UP Xtreme i12
- 11 UP Squared Pro 7000
- 19 UP Squared V2
- 59 UP 4000
- 35 UP Squared 6000
- 60 UP Squared Pro
- 143 UP Xtreme
- 837 UP Squared
- 222 UP Core
