[SOLVED]RAM Test Algorithm
invis
invis New Member, UP reseller Posts: 8 ✭
May I ask you for a hint how to perform a test of RAM memory on board UPS-APLP4-A20-0432
Our clioent states that read errors are occured. MAy I ask you to provide me an algorithm in order to test the memory ? On this computer LINUX UBUNTU has been installed, possibly those errors might be caused by hardware inconsistency with this LINUX distribution.
What OS and application should be installed on the board in order to perform reliable RAM memory test ?
I will be grateful for your advice,
Regards,
Pawel.
