Sata port/controller hot plug support UPS-APLP4-A10-0864
Fereffe
Fereffe New Member Posts: 1
edited May 2019 in UP Squared Windows
Hi all,
does the sata port/controller of the UP Squared Pentium Quad Core 8GB memory/64GB eMMC (Intel N4200) support HOT PLUG?
I need to attach the device to the sata port after the system is up (Windows 10), so I'd like to know before I purchase the board.
  • rogertsai(AAEON)
    edited February 2020
    @Fereffe
    Yes, the SATA port hot plug is supported on UP^2, and you will just need to enable SATA hot plug in BIOS,
    After entering the BIOS setup, please go to the "Chipset" --> "South Bridge" --> "SATA Configuration" ---> Enabled to "SATA Port 0 Hot Plu"
