[SOLVED]Booting yocto image on UP squared
hello everyone,
I'm searching for a solution to install and boot my yocto image on the up squared board, this web site : https://downloads.up-community.org/download/yocto-2-5-sumo-evaluation-image-for-up-squared/ is not working.
I also have issues with the dnf command in fact each time I use this command it says :
there are no enabled repos.
thank you in advance,
Hi @baxbony
We updated the release with 2 images:
dnf is installed but we don't provide any repositories, you can create by yourself after doing a yocto build on your side.
It looks like the links to the Yocto images are dead. Are there any mirrors?
Hi @RiversideRI
It should work now.
Looks like these are dead again
can you help @krishnaorakkan?
