There is no wifi after .hddimg is installed
My device is https://www.aaeon.com/en/p/iot-gateway-ups-gws01 and I follow https://github.com/AAEONAEU-SW/meta-up-board/tree/sumo to build a .hddimg.
However, there is no wifi interface in ifconfig and "iwlist wlan0 scan" is not working.
[email protected]:~# ifconfig
docker0 Link encap:Ethernet HWaddr 02:42:AA:0F:53:0C
inet addr:172.17.0.1 Bcast:172.17.255.255 Mask:255.255.0.0
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 TX bytes:0 (0.0
enp2s0 Link encap:Ethernet HWaddr 00:07:32:58:DB:91
inet addr:172.23.115.28 Bcast:172.23.115.255 Mask:255.255.254.0
inet6 addr: fe80::207:32ff:fe58:db91/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1359 errors:0 dropped:65 overruns:0 frame:0
TX packets:103 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:112580 (109.9 KiB) TX bytes:15523 (15.1 KiB)
enp3s0 Link encap:Ethernet HWaddr 00:07:32:58:DB:92
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:86 errors:0 dropped:0 overruns:0 frame:0
TX packets:86 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:6630 (6.4 KiB) TX bytes:6630 (6.4 KiB)
[email protected]:~# rfkill list all
0: hci0: bluetooth
Soft blocked: yes
Hard blocked: no
build command:
TEMPLATECONF=meta-up-board/conf source oe-init-build-env
MACHINE=up-squared bitbake upboard-image-base
Thanks.
Best Answers
You'll need a custom kernel config to compile the ath10k drivers, and then add the firmware to your image for the 10k chipset, the package name is: linux-firmware-ath10k
You can add it by editing whatever image definition you are using with the a line like this:
IMAGE_INSTALL += " linux-firmware-ath10k"
Kernel config lines can be added to the this file locally if you don't have your own bbappend file setup for custom kernel configurations . https://github.com/AAEONAEU-SW/meta-up-board/blob/sumo/recipes-kernel/linux/files/up-board-user-config.cfg
You can find the kernel config lines here
https://wireless.wiki.kernel.org/en/users/drivers/ath10k/configuration -
I did forget you will need to clean the sstate of your kernel first to pick up the change to your kernel config, then rebuild your image. This command should do it for you:
MACHINE=up-squared bitbake -c cleansstate virtual/kernel
the wifi on that product is optional.
Are you sure you got the one with the WiFi module installed?
Hi DCleri,
Thanks for your reply.
I use a bootable USB stick to boot "ubuntu" for USB and there is a wifi interface (wlp4s0) in ifconfig.=============================================================
[email protected]:~$ ifconfig
enp2s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 172.23.115.37 netmask 255.255.254.0 broadcast 172.23.115.255
inet6 fe80::1ebd:6bf0:a639:4663 prefixlen 64 scopeid 0x20
ether 00:07:32:58:db:91 txqueuelen 1000 (Ethernet)
RX packets 5431 bytes 2773744 (2.7 MB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 1325 bytes 122834 (122.8 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0enp3s0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 00:07:32:58:db:92 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0
TX packets 0 bytes 0 (0.0
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1000 (Local Loopback)
RX packets 174 bytes 14744 (14.7 KB)
TX packets 174 bytes 14744 (14.7 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0wlp4s0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether f8:a2:d6:76:6d:99 txqueuelen 1000 (Ethernet)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0[email protected]:~$ iwlist wlp4s0 scan
wlp4s0 No scan results[email protected]:~$ iwconfig
lo no wireless extensions.enp2s0 no wireless extensions.
enp3s0 no wireless extensions.
wlp4s0 IEEE 802.11 ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=0 dBm
Retry short limit:7 RTS thr:off Fragment thr:offPower Management:on
Cheers,
Likku -
can you please identify the type of wifi card using dmesg?
Hi DCleri,
Thanks for your help.
The dmesg of yocto and ubuntu are attached.
In ubuntu_demesg.txt, the log listed below may be related to wifi.[ 32.303272] ath10k_pci 0000:04:00.0: qca6174 hw3.2 target 0x05030000 chip_id 0x00340aff sub 11ad:0808
[ 32.303277] ath10k_pci 0000:04:00.0: kconfig debug 0 debugfs 1 tracing 1 dfs 0 testmode 0
[ 32.304069] ath10k_pci 0000:04:00.0: firmware ver WLAN.RM.4.4.1-00079-QCARMSWPZ-1 api 6 features wowlan,ignore-otp crc32 fd869bebBTW, the model of my device is "UPS-VKIT01-GWS01X7-A20-0464".
Cheers,
Likku -
Thanks @likku
So the WiFi is working correctly on Ubuntu? Can you confirm?
We will review why with the Yocto image the WiFi firmware is not loaded and we will come back to you asap
- 287 All Categories
- 104 Announcements & News
- 47 Product News - New Product/Product Change Notice/ End-of-life
- 179 Welcome Developers!
- 18 Tech Updates
- 380 UP Products
- 6 UP Xtreme i11
- 15 UP Squared 6000
- 38 UP Squared Pro
- 126 UP Xtreme
- 796 UP Squared
- 86 UP Core Plus
- 41 UP AI Edge
