GPIO interrupt causes kernel panic
Hi, I've found that I can't configure any of the GPIO pins to handle interrupt requests. The following is an example which fails when trying to set Linux GPIO 5 as an IRQ pin:
$ echo 5 > /sys/class/gpio/export
$ cat /sys/class/gpio/gpio5/value
1
$ cat /sys/class/gpio/gpio5/direction
in
$ echo rising > /sys/class/gpio/gpio5/edge
kernel panic
Specs:
Hardware: UP-CHT01
OS: Ubuntu 16.04.5 LTS
Kernel: 4.15.0-37-generic
BIOS: UPC1DM15
Thanks.
Any thoughts? Anyone else experiencing this issue?
@scint Did u solve the issue ?
Have you followed the instructions to install the UP Kernel (based on Ubuntu 4.15)?
https://wiki.up-community.org/Ubuntu#Install_Ubuntu_for_UP.2C_UP2.2C_UP_Core_and_UP_Core_Plus
@DCleri please look at my post (https://forum.up-community.org/discussion/4156/gpio-interrupt-does-not-work-killed)
