[Solved] Where can I get a UP board SDK to write my software to control GPIO pins?
I am currently developing software to run on UP Board. I am looking for a SDK / Window 10 to run on UP Board. I would like to control GPIOs pins in the UP board.
Do anybody know the URL to UP Board / SDK / Windows 10?
Thank you,
Mike
Hello, please follow the link
https://forum.up-community.org/discussion/2019/adc-under-windows-drivers-when-available
Download this too:
ftp://dataex.aaeon.com.tw/Hi-Safe_v2_20180111.zipFirst update your BIOS to lastest Version
Keep in mind to install AEEON FrameworkAfter I installed this I was able to use the GPIOs with Windows 10 Full
Thank You. I got it working.
What/where is the AEEON Framework? When will a SPI driver be available?
Tim,
Using this FTP ftp://ae:aaeonae@dataex.aaeon.com.tw to download Hi-Safe_v2_20180111.zip file. The Hi-Safe_v2_20180111.zip contains the AEEON Framework. I don't know anything about SPI driver. Look in the FTP site to see if SPI example available. -
It looks like there's a new Hi-Safe on the ftp (I have a script watching for uploaded files) has anyone looked into this?
ftp://dataex.aaeon.com.tw/COM/
It's at this folder.
@Rockin_Caterpillar said:
It looks like there's a new Hi-Safe on the ftp (I have a script watching for uploaded files) has anyone looked into this?ftp://dataex.aaeon.com.tw/COM/
I tried this one out on the Windows 10 system that I am trying to get working and I did not get the sound out from the I2S/PCM_DOUT like before. (It was not the correct sound before, but it was a sound.) However I was also trying to run the OS from a Virtual Drive and I also installed newer driver set from the Windows setup instruction wiki. I'll do more testing.
Okay have tested on a simple installation of Windows 10, v1703 and it did fine with latest drivers.
we are using the DIO SDK and we have problems to know how to activate pins we want to use. In Linux we have 2 options, but in windows we don't know how to proceed.
If we want to activate Pin13 as a output, we use the command: EAPIGPIOsetdirection
Which id should we use to activate the fiscal pin 13? -
What is the username and password for the FTP site?? I've tried my forum information without success.
Im in same boat. Did this not require Username Access before?
I have the details if you still need them.
@karlhm76 Can you please share the Username and Password with me? Thanks.
Hi All,
The latest Windows drivers and SDK are available from our Downloads section on the UP Community: https://downloads.up-community.org/download/up-sdk-for-windows-10-and-windows-iot/
@DCleri said:
Hi All,The latest Windows drivers and SDK are available from our Downloads section on the UP Community: https://downloads.up-community.org/download/up-sdk-for-windows-10-and-windows-iot/
Thanks for the links
