Install of Software Packages Fails
Palinka
Palinka New Member Posts: 3 ✭
But the general system works.
Here from syslog:
13 15:11:50 in-target: Get:71 http://httpredir.debian.org/debian/ jessie/main printer-driver-pnm2ppa amd64 1.13-6 [184 kB]
Jun 13 15:11:50 in-target: Get:72 http://httpredir.debian.org/debian/ jessie/main printer-driver-postscript-hp all 3.14.6-1 [873 kB]
Jun 13 15:11:50 in-target: Get:73 http://httpredir.debian.org/debian/ jessie/main printer-driver-ptouch amd64 1.3-8 [28.9 kB]
Jun 13 15:11:50 in-target: Get:74 http://httpredir.debian.org/debian/ jessie/main printer-driver-pxljr amd64 1.4+repack0-4+b1 [27.4 kB]
Jun 13 15:11:50 in-target: Get:75 http://httpredir.debian.org/debian/ jessie/main printer-driver-splix amd64 2.0.0+svn315-4 [42.1 kB]
Jun 13 15:11:50 in-target: Get:76 http://httpredir.debian.org/debian/ jessie/main cups-bsd amd64 1.7.5-11+deb8u1 [35.2 kB]
Jun 13 15:11:50 in-target: Get:77 http://httpredir.debian.org/debian/ jessie/main tk amd64 8.6.0+8 [5,388 B]
Jun 13 15:11:51 in-target: Fetched 31.6 MB in 7s (4,176 kB/s)
Jun 13 15:11:51 in-target: E
Jun 13 15:11:51 in-target: :
Jun 13 15:11:51 in-target: Failed to fetch cdrom://[ubilinux GNU/Linux v3.0-rc2-2-g68ea9c9 _Jessie_ - Official amd64 STICK1GB Binary-1 20160526-20:14]/pool/main/w/wpa/wpasupplicant_2.3-1+deb8u3_amd64.deb  Hash Sum mismatch
Jun 13 15:11:51 in-target: Failed to fetch cdrom://[ubilinux GNU/Linux v3.0-rc2-2-g68ea9c9 _Jessie_ - Official amd64 STICK1GB Binary-1 20160526-20:14]/pool/main/s/sudo/sudo_1.8.10p3-1+deb8u3_amd64.deb  Hash Sum mismatch
Jun 13 15:11:51 in-target: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Jun 13 15:11:51 in-target: tasksel: apt-get failed (100)
Jun 13 15:11:51 main-menu[2430]: WARNING **: Configuring 'pkgsel' failed with error code 1
Jun 13 15:11:51 main-menu[2430]: WARNING **: Menu item 'pkgsel' failed.
Jun 13 15:11:56 main-menu[2430]: INFO: Modifying debconf priority limit from 'high' to 'medium'
Jun 13 15:11:56 debconf: Setting debconf/priority to medium
Jun 13 15:11:57 lilo-installer: LILO not usable on EFI PCs without BIOS compatibility; use grub-efi
Jun 13 15:12:02 main-menu[2430]: INFO: Menu item 'save-logs' selected
Jun 13 15:13:04 kernel: [  707.315306] TCP: request_sock_TCP: Possible SYN flooding on port 80. Sending cookies.  Check SNMP counters.
Jun 13 15:13:12 kernel: [  714.755026] TCP: request_sock_TCP: Possible SYN flooding on port 80. Sending cookies.  Check SNMP counters.
