Install of Software Packages Fails
Palinka
New Member Posts: 3 ✭
But the general system works.
Here from syslog:
Here from syslog:
13 15:11:50 in-target: Get:71 http://httpredir.debian.org/debian/ jessie/main printer-driver-pnm2ppa amd64 1.13-6 [184 kB] Jun 13 15:11:50 in-target: Get:72 http://httpredir.debian.org/debian/ jessie/main printer-driver-postscript-hp all 3.14.6-1 [873 kB] Jun 13 15:11:50 in-target: Get:73 http://httpredir.debian.org/debian/ jessie/main printer-driver-ptouch amd64 1.3-8 [28.9 kB] Jun 13 15:11:50 in-target: Get:74 http://httpredir.debian.org/debian/ jessie/main printer-driver-pxljr amd64 1.4+repack0-4+b1 [27.4 kB] Jun 13 15:11:50 in-target: Get:75 http://httpredir.debian.org/debian/ jessie/main printer-driver-splix amd64 2.0.0+svn315-4 [42.1 kB] Jun 13 15:11:50 in-target: Get:76 http://httpredir.debian.org/debian/ jessie/main cups-bsd amd64 1.7.5-11+deb8u1 [35.2 kB] Jun 13 15:11:50 in-target: Get:77 http://httpredir.debian.org/debian/ jessie/main tk amd64 8.6.0+8 [5,388 B] Jun 13 15:11:51 in-target: Fetched 31.6 MB in 7s (4,176 kB/s) Jun 13 15:11:51 in-target: E Jun 13 15:11:51 in-target: : Jun 13 15:11:51 in-target: Failed to fetch cdrom://[ubilinux GNU/Linux v3.0-rc2-2-g68ea9c9 _Jessie_ - Official amd64 STICK1GB Binary-1 20160526-20:14]/pool/main/w/wpa/wpasupplicant_2.3-1+deb8u3_amd64.deb Hash Sum mismatch Jun 13 15:11:51 in-target: Jun 13 15:11:51 in-target: E Jun 13 15:11:51 in-target: : Jun 13 15:11:51 in-target: Failed to fetch cdrom://[ubilinux GNU/Linux v3.0-rc2-2-g68ea9c9 _Jessie_ - Official amd64 STICK1GB Binary-1 20160526-20:14]/pool/main/s/sudo/sudo_1.8.10p3-1+deb8u3_amd64.deb Hash Sum mismatch Jun 13 15:11:51 in-target: Jun 13 15:11:51 in-target: E Jun 13 15:11:51 in-target: : Jun 13 15:11:51 in-target: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing? Jun 13 15:11:51 in-target: Jun 13 15:11:51 in-target: tasksel: apt-get failed (100) Jun 13 15:11:51 main-menu[2430]: WARNING **: Configuring 'pkgsel' failed with error code 1 Jun 13 15:11:51 main-menu[2430]: WARNING **: Menu item 'pkgsel' failed. Jun 13 15:11:56 main-menu[2430]: INFO: Modifying debconf priority limit from 'high' to 'medium' Jun 13 15:11:56 debconf: Setting debconf/priority to medium Jun 13 15:11:57 lilo-installer: LILO not usable on EFI PCs without BIOS compatibility; use grub-efi Jun 13 15:12:02 main-menu[2430]: INFO: Menu item 'save-logs' selected Jun 13 15:13:04 kernel: [ 707.315306] TCP: request_sock_TCP: Possible SYN flooding on port 80. Sending cookies. Check SNMP counters. Jun 13 15:13:12 kernel: [ 714.755026] TCP: request_sock_TCP: Possible SYN flooding on port 80. Sending cookies. Check SNMP counters.
Hi Palinka,
Thanks for the report! Were the [tt]sudo[/tt] and [tt]wpasupplicant[/tt] packages installed in your system despite those errors? -
Sudo was not installed, I installed it via recovery. For the moment im running a minimal ubuntu with openbox, so I can't check back for wpasupplicant.
Follow-up: these issues should be fixed on the ubilinux 3.0 release. We will be dropping support for the older release candidates.
