[SOLVED] Disable graphical interface.
Dear all,
does someone of you know how to totally disable the graphical interface and start the system only in the terminal mode?
Thanks.
Silvano
Eng. Silvano Bertoldo, PhD
Dear all,
Thanks.
Silvano
Try this as sudo user (and perhaps test it first in a non-critical set-up):
systemctl get-default
This should show you the current setting, i.e. graphical.target
Then confirm that the terminal mode is available (it's called multi-user.target) in the list of target files:
systemctl list-unit-files --type=target
If you have multi-user.target in the list of target files you can proceed with setting it as the new default target:
systemctl set-default multi-user.target
If you now reboot the system it will boot into terminal mode, i.e. it will give you a shell with login prompt instead of the desktop
You can of course get back to the graphical mode by
systemctl set-default graphical.target
and rebootOk, thanks!
I'll try it!
Silvano
