Constant reboot
Denon
Denon Posts: 6
My UP board is basically unusable recently because anything I do with any browser (firefox, chrome, opera) causes it to crash and reboot. It started about 2 months ago and has progressively got worse. It started with Ubuntu 16, I upgraded to 17 and now 18.04 and none of the upgrades have changed anything. It is running kernel 4.15.0-52-generic. I couldn't even write this post using the UP because it would crash and reboot. Any ideas? Anyone else having similar problems?
  • Denon
    Denon Posts: 6
    This need to be moved to Linux section. I posted in the wrong section.
  • snuhg
    snuhg Posts: 14
    How did you do the upgrade to newer versions of Ubuntu? Upgrades via apt-get package manager do sometimes mess things up. If possible, try a clean new install of 18.04 (use the option to erase the existing OS on the hard disk). If that does not fix it, test another power supply.
  • Denon
    Denon Posts: 6
    I ordered a new beefier power supply for it today. Note: The problem started before any of the updates back with Ubuntu 16.04. The upgrades I don't believe are the problem. I'll find out next week if the new power supply fixes the problem.
  • Denon
    Denon Posts: 6
    new Power supply seems to have solved the problem. WooHoo!!
