No boot with enabled MIPI and 7" touchscreen from UP
panel support enabled
1024x600
board reformatted
get this message.
without panal support its starts normaly.
1024x600
board reformatted
get this message.
Same issue here with 10.1" touchscreen from UP
I'm using the 10.1" touch screen. I have 5 units with the touch screen kit and up board. I was able to get 2 to work, but the other 3 do not. If I reset the BIOS to default "optimal" values using the F3 key, I can boot to an external HDMI monitor. But, if I enable MIPI I get either a black screen, a black screen with an underscore, a list of error messages or some bizarre video. I'm thinking there is some phantom BIOS that is in conflict with the BIOS I'm adjusting.
Hi, I don't know if its a kms or a bios problem...
I get my panel working by changing force lit status to off in bios
but it only works with an monitor on HDMI
i hope someone will find a solution soon
the system will boot on hdmi when xserver initiate the driver the panel goes on
i hope this helps someone or it is a start to find a solution
but this is no solution for me...
I use the 10.1"Panel -
Dear Jonbkruse, can you please try to install the evaluation version of Windows, select from the Bios of Up the 10.1"W 1280x800 and let me know if the LCD is working?
Ricky
